I can confirm there is no smoke anywhere (didn't power it up, though). Anything else I should check? 😀
Sven
Sven
This is probably obvious for everybody here but me (so please be patient with Gruenschnabel) - the diode testing is also good to find out whether it is an npn or pnp pair, right? I did literally glue them together the first time (heat conductive adhesive) and the writing is really hard to read on some pairs...
Q4/5/6/7 = NPN
Q4A/5A/6A/7A = PNP
Correct?
Sven
Q4/5/6/7 = NPN
Q4A/5A/6A/7A = PNP
Correct?
Sven
yup , correct ( for PNP and NPN ; I didn't checked Q numbers ...... too lazy now )
ZM knows Station ......
I guess you do
Firing up Shuntys take two in 6,5,4,...
😉Firing up Shuntys take two in 6,5,4,...
We are getting better 😉. Shunty 1 - works fine. Shunty 2 - one channel works fine, other channel delivers 40.5V and does not react to trimmer. I will look at it again tomorrow...
Abraxas336 said:We are getting better 😉. Shunty 1 - works fine. Shunty 2 - one channel works fine, other channel delivers 40.5V and does not react to trimmer. I will look at it again tomorrow...
naah . .... that was just a small Badaboom .......
Annoying, nevertheless. I just realized that the Shunty that works on both channels does not have JP2/JP2A set (somebody told me to take it out).
Abraxas336 said:Annoying, nevertheless. I just realized that the Shunty that works on both channels does not have JP2/JP2A set (somebody told me to take it out).An externally hosted image should be here but it was not working when we last tested it.
Quick hint....take the jumpers out of the other board 😉
Magura 🙂
maybe you have shortie between some part and upper groundplane ; if you remove JP2 then upper copper plane isn't anymore connected to gnd , so shortie is harmless .
try that with other Shunty too , as Metaldanske wrote already
edit:
I think I wrote in Cookbook - use either JP2 OR JP2A ;
not both ,, or you are risking hum
I'm not using both. Good news: using JP2 on the working Shunty does not change anything, it keeps working fine. Confusing: cutting the jumper on the other one (one channel fine, one always @ 40.5V ) makes both channels go to 12.1V and no reaction to trimmer.
Abraxas336 said:I'm not using both. Good news: using JP2 on the working Shunty does not change anything, it keeps working fine. Confusing: cutting the jumper on the other one (one channel fine, one always @ 40.5V ) makes both channels go to 12.1V and no reaction to trimmer.
take day or two pause ;
then recheck all visually , using magnifier and good light .
sometimes that route is good , not because you are going to find shorts or breaks , but you are also checking parts and values ....
Well I managed to stay away for 7 hours 😀. I washed the BCBs and after looking at the now clean solder joints I suppose there is one Gate not properly soldered (non working channel).
Unfortunately I had to go to work then.
Will report tonight....
ITS ALIVE!!!
Thanks Choky & Magura!
PS: My Preamp can make the light flicker 😀
PPS: If I catch the guy who left this mess at my work place...
Abraxas336 said:
Congratulations 😎
So, now you have not only made a Shunty kit work, but learned a few things in the process.
That's gonna make your next project somewhat easier.
Magura 🙂
- Pumpkin preamp - ordered by Steen , official making thread
