Pumpkin preamp - More Boring Making Thread
Re: Pumpkin Volume Control
Algar_emi said:
Hi. What would be the best volume control for the pumpkin?
It is a balanced input preamp, so a few question:
If use as single ended, do we just ground one input and input the signal into the remaining input, any side is better than the other for that?
-I guest we need a balanced volume control. Is this balanced 5K serie attenuator fro K&K audio a good choice: http://www.kandkaudio.com/linestage.html
any other suggestion?
Thanks in advance.
I think that I covered that in Cook Book's addendum ......
anyway - either using input or output unbalanced - most convenient is to ground minus leg , and use positive leg as hot
use whatever attenuator or pot ( up to 50K) , but have that on mind - shunt attenuator ( as shown on that link ) have variable output/input impedance
for Pumpie that isn't problem,but for some sources can be .
edit :
if you choose pot ........ our friend at Dantimax (lookie lookie) have some interesting things
Manu said:
Forget it, I wont publish anything.......Sad enough, this would be an even greater thing than the Pumpkin😉 Let the publishers publish the project, I am surely not gonna do it😀 What I can tell you, is that the guys did notice my favourite transistor!!! Namely the Toshiba 2SK369's....he-he Try and get your hands on some of those.... Inductors/2SK369's he-he..... start to compute
jacco vermeulen said:
get some 30mA 2SK163.(or kill some Waflers)
besides Waflers .......... ( I still dunno whazzat )
all I can find ( ECA TDV 2002) about is that 163N isnogood above 18mHoomps , and that xconductance is pretty venerable - in range of 9mS
369 isnogood above 30mHoomps and xconductance is not so venerable ..... in range of 40mS
wackoo dutchie - send me all yours 369s , I'll match them for ya , and never send them back 😉
Like Wafler 915 pre-amp.
(date postponed 4th time, dr Not Again must have a busy golf schedule, one more time and me fly across the border,...if i can find the exit. Fortunately me not got bill yet and the laserpeep show is fully tax deductable since Jan 01)
ps: you have already enuff OP and uther parts for MA critter ?
(or some gau-duhh cheese, i haven't been able to swallow that stuff for ages anyway)
GoldMember
dreky layzeer holder ............ :cuss:
regarding MA furnace - I have those TO3 oldies (135/50) , no more no less than 4 pairs , , nuff 170BL/V for matching, plenty BC variety instead of dreky TO92 Japs ......... ya can help me if you have :idea: regarding best european tippies for rest of circ .......... me hate to chase jap fuses :clown:
No likey new sets of OP pairs ?
I have those mentioned ; it's sacrilege to let them sleep ,and they aren't worse than origigi ones , I presume
what's wrong with plain K389 shtr on the input, why 170s ?
I have mucho BL/V , but just few 389s
Take pick: original 2x A1145/C2705, or A1360/C3423. or fatter ones like A1306/C3298 if you nutz.
I can't see that you mention any eu tippie ....... :rofl:
Variac said:
It BETTER be scary good or a mod posse is comin' for ya-
That means me buying Cal a plane ticket! 😉
misrepresentation of preamp SF - scary factor- 10 yrs in the bin!
:devilr:
But seriously, you say about any pot up to 50k will work with the Punky. That sound unfussy and aggreeable - like it's father..
I'll soon be ordering resistors for a switched attenuator (not shunted)
Since it can be any value up to 50 is there a preference depending on the amp input impedance or somethin'? Listening to SY, (I'm gonna stop taking advice RIGHT after you give me some!) I made my F4 with 200k impedance so his drecky tube pre will be all that it can be! Gotta take advantage of those JFETs! Would that point to a particular pot impedence? Otherwise I'll probabbly go 20-25 K or some such for the thing....
variac
look here: http://tiny.pl/p4bs
if you prefer lower version (10K ,for instance - better - if your sources can handle ) - look for other items of seller
you can hardly make it cheaper
edit .......... my brain is choking , evidently ....... that's just two channel version ................. I can't remember does he 4 channel versions........ 😕
still - worth cheking
Zen Mod said:
color of the month
Zen Jacques Zissou jr.
(Nelson Santa Zissou at the wheel of course)
Can a Pumpkin run on a power supply of +30v/-30v?
If so, are there any changes needed to the components or setup? Or will that affect the linearality of the the Fets or have an adverse effect on the sound?
I do not need such a high gain anyway, thinking of going for a gain of 10 or less (probably 5-7) - will adjust the necessary resistors for those gain.
Asking because I have a regulated linear supply of +30V and -30V on hand.
her shann
her shann
naah - just go for it ;
in Cook Book you'll find everything you need to know about setting gain for your needs ;
just one note - and you'll probably note my words not as ones from seller , but .........
without shunt reg ( not just Shunty , any other decent shunt reg) Pumpkin is very decent preamp ;
with shunt reg - it's great preamp .
few volts up or down aren't so important .
Zen Mod,
looks like I'll be going shunty then, I'll email you when I am ready to get the boards and matched transistors.
Say I use a 10k ohm pot, what's the input impedance of the pumkin if the attenuator is set to minimum?
her shann
