Power Supply with Active Rectifier, RF Filter and Super-Regulator
Here we go again….😂
Another R25 bipolar supply in the works. This one will replace an existing SMPS in my ZD25 Mini (Holy Grail Follower) amplifier.
Thanks Tombo, you have shared a fantastic psu creation 🙂.
Would 0.25w resistors suffice for all/any positions on 'R25'.?
0.25 W resistors can be used perfectly well for all positions except R8 & R9. Those two can be 0.25 W for the often used 22 – 30 V, but not for the higher output voltages. Though, they will be warm during operation.
There is also a question at what temperature rise is that 0.25 W dissipation declared. Resistors like Dale CMF/RN60 are specified for only 0.25W while other manufacturers would specify such big body resistor for 0.6 – 1 W.
Gentlemen,
need help!
For an integrated rectifier LT3420, how much higher should the FET current value "ID" be than the PSU output current?
For example,
If the preamplifier requires 24V 1A, is it enough to use a FET with a current of 10-20 A "ID"?
Current is not the only critical property of MOSFET used with the LT4320 but 10-20A would be enough.
I would recommend to stick with the BOM proposed parts for any design (is here prasi’s LT4320 CRC board in question?).
Designs can be altered but it could end like this:
* picture borrowed from here.
Reactions: poseidonsvoice
If anyone in the USA would like to try out @tombo56 R25 boards, I ordered a bunch just before the de minimus rule dissapeared for packages from China.
Boards are 2mm PCB, 2oz Outer copper, white silkscreen, HASL.
Since folks outside the US can still order these direct from JLCPCB, that's they best option still due to high international shipping cost. I'm hoping to help out folks in the US who just missed the opportunity to sneak in a PCB order before the May 2, 2025 deadline kicked in. I posted them up in the swap meet.
Thanks Tombo for sharing freely the great board design!
No not just crossing but also full short AFAIK. Anyway, it would have been a disappointing experience. If not yet experienced enough just keep exactly to the BOM without any deviations/interpretations and triple check everything before thinking of powering it.
Maybe show it with pictures here before that.
