Vintage transformer
galery...
It's 250 VA c-core transformer.
Exelent for power tube amplifier wityh rectifier.
Doiuble anod section.
This good for PP amplifiers or SE woth antifase secondary.
Good for Se transformer for ear gap...
This core give ability to make the minimalisation of negative capasitance ...
galery...
Vintage transformers...
galery...
Tis transformer have sections wioth high viltage near 320 V.
Some secondaries for 6.4 V
Primary 220V.
Power is 270 VA.
This core is exelent for power transformers and other tube eqipment....
For Push-Pull for GM70 tubes.
And for SE...
And for the power, rectifier doubl anoe section...
galery...
Primary 220V.
Power is 270 VA.
And for SE...
Choke 0.1
This choke is have 3000 wounds of cuper ware.
It's have different Io : 100 ma ,200 ma
Max curent is 250ma
Inductivity from 20-40 Henry
This variant with ready the wound.
Ater that this choke will be painted (carcass and core).
and pront the spec on it...
The ware will be soldered...
Max curent is 250ma
The unpainted chokes
The small is CHoke 0.1
The big is CHoke 0.4
This big variant have the cuper ware near 0.5 mm (diameter).
The maximum curent is up tp 1 A.
I am use for 250 ma.
i love big diameter cuper and cores for minimalise THarmpnic Distortions, Faze Distortions and dinamic sound. Gradient from loud and low music sound...
All this chokes have the risistens from 20-40 Ohm...
This transformers wate the painting and printing...
Little babies...
It's my little babies.
Toroid core from 1500VA eqipment.
This I am use for 25 VA load for my new power amplifier...
This amp will be have 6 transformers...
the primary is double 0.5 mm cuper ware.
4 wounds per 1 V...(220*4=880
Core is 20 sm2...
the secondary is silc lack cuper 0.5 mm.
Big dimentions. low price is a good for trading here...
I think the high-end mans many here that plays with real transformers, no with china trafos with dimenton like my finger and cuper wich make fare from little thikness...
Core is 20 sm2...
The cuper ware for transformers
The cuper wire for transformer is 2-3 mm...
This milti-cuper ware I am use at the secondarie of power or output transformer...
Diameter near 3 mm for 6-10 W power...
For Ultra-high-end output transformer - double wire.
The wire is in film isolation.
For low loss and minimalise the negative capasitance and inside inductivity....
- Vendor's Bazaar
- Power and Output transformers for sale
