Power Acoustik BAMF 5500 driver board part number
Hi All,
I want to know the part numbers for the above mentioned amplifier transistors on driver board Q110 and Q111. Thank you.
Best Regards
Imraneesa
Sometimes the sockets get lose and don’t make full contact with the pins on the driver board . And this is what cause’s the amp to go into protection
Try plugging the driverbiars back in and twist is slightly to the right and hold it there and then try powering it up see if that helps .
I have seen several of these amps so this
