Post your Solid State pics here
Joined 2018
DIY an other CRESCENDO MILLENIUM
Elektor stopped PCB sales for Crescendo millennium a few years ago, so I created a new PCB.
I just finished my Crescendo Millennium modified and adapted with only one PCB that I design, it includes the amplifier board and protection DC board, which was composed of 2 PCB by Elektor April 2001.
The amplifier works perfectly without hummmm, it can deliver 28Vrms under a load of 8 ohm. The sound is excellent and very pure, I would say crystalline .........
Joined 2018
Hicoco, I like the white pcb’s as you don’t see this colour often but makes sense for easy read of labels. Do you have the air grills in the cover aligned with the heat sinks inside?
Thanks, the air grills are on a rear cover but all the a bottom is with hole , the max temp is 50℃ inside after one day playing music
2x200w in 4ohm, 2x125w in 8ohm, slew-rate 80v/usec, THAT 340 bipolar array input stage, no Miller compensation, 1kva toroidal transformer with 3 belly bands(2 of GOSS and one mu-metal, 88.000uF, dual monoblock, separate voltage rails for weak signal stages and output stage, full aluminium housing.
