Post your Solid State pics here
The top of the amplifier was installed and it was running for about an hour which is sufficient to know. The temperature stopped climbing after ~40 minutes. Anyways, the 100 watts is a dream but in reality I will most probably put it at around 40 watts in Class A, it gets too hot in the room. In reality and practically, 25 watts in Class A should be sufficient and the rest in AB.
I have to test my comfort level in the room after setting the bias to be at 40 watts in Class A and if too hot in the room bring it down. It will also save on electricity! 😀
Ciao!
Do
I am using that setup as we speak, 4 aleph mini's 20 watts each class a, and a 200watt high speed class a/b..
AB CLASS AMP
Mono ab class amp
