Poor Serbian Man Optical Volume Control
this must be wrong.
Specifications and measurements show that b and c grade are different.
specifications - yes ;
measurements - yes , if you're lucky to obtain real thing ;
I'm not losing my sleep with difference between B and C range .
anyway - every single one is checked with Hfe test on my bench , prior to soldering ...... result of years of service work .
Hi to the both of you,
thanks a lot....your great.
Last question:
How do i set this thing up?
How to use the JMP_01 and 02 and what exactly to set up
with P3 and P1/2??
Okay that was two questions, so i will add a third one....
Did you measure exact input and output-imp. of LDR-
attenuator?
Greetings ulf
Last question:
with P3 and P1/2??
attenuator?
Greetings ulf
ZM, I also hopped to see this inside Cook Book - You lazy guy😀
This requires a more than a few sentences, so please be patient until tonight.
If ZM will not post something in short, I'll prepare the procedure later today.
Not remembering that we measured impendance...
BR//
Has anyone but together a BOM on Mouser/Digikey ... just wanted to check before I
re-invent the wheel! If anyone is interested in helping I would be willing in ordering multiples (up to a point 🙂 ) and shipping them out
