It looks like both the attenuator and buffer boards can be used for 4 channel unbalanced, is this the case?
Thanks.
yup 😉
Hello
while I´m waiting for the Pumpkin and PSMLA packages, I´m looking for reply some question in the threads but I haven´t found this:
I´m not sure if the transformer is the same for PSB01 and PSB02.
In the buffer, P1…P4, don´t perturb the signal the same of any one potentiometer?
If the LDR be matched. Is convenient put the cups of 47nF and 100uF?
Same dual 10k dual pot form Digikey?
Can any body help me please?
Best regards
José H.
Best regards
José H.
Hello
Best regards
José H.
Jose - sorry ..... I'm overwhelmed these days with e-mails , work , trying to finish that Cook Book ..... seems that I have some sort of Lazy Flu ........
or is that just lack of energy ........ probably main reason is too prolonged period of multitasking .......
yes - you can use same (one) xformer for both PCB01 and PCB02
2x15V / 15VA xformer will suffice for both
multiturn pots in buffer sources are harmless , soundwise
you can decrease these electrolytics to 10uF , and even omit them , without any ill effect
2x10Klin pot can be cheapest generic one .
Joined 2002
Thank you for the quick reply.
Don´t worry, I suppose you have a lot of work.
Let me know when you send me the package.
Finally Can you put one more LDR matched quad?
certainly I can ..... 😉
Just a bump to the top and a poke about the cookbook. Anytime soon? My impass is nearly running and in need of attenuation.
- Analog Line Level
- Poor Serbian Man Optical Volume Control
