Point to point wiring
Given the choice, my customers prefer the PCB version. Modular and easier to service if need be.
I swore by point to point before I figured out how to make PCBs in EasyEDA and the cost is lower than the terminal strips I used to use by a margin.
I'm surprised nobody mentioned the late Kondo-San so far: a true work of art that has its place in the MOMA, if you ask me,
  • Thank You
Reactions: cumbb and twocents
Well, I found a chassis and decided to wire-up a bunch of parts lying about the workbench. That took quite awhile....more than quite awhile. Those darn parts were actually all over the garage. 🙄
I decided I had enough fun wiring-up bits, but few wires were still hanging out. Luckily the chassis had a few open holes for them to go into...so that looks tidy at last! 🤓
Now what to do with that blank open area in the middle? 🤔
Maybe it can be modified into a tube power amp? O.K., but it will be my first tube project, so we will see what happens... 😵
Could not resist joining in... 😉
David
P.S. It really is my first tube project.
Fits like a jigsaw. Out of interest, how did you plan this?
Hopefully the "jigsaw" will add up to a complete "picture", when completed...🤓
The short version, 😴 , is that I mock-up the physical part locations and build the whole assembly slowly in my mind's eye. Parts can be moved around, swapped, viewed at different angles, etc.
As one builds, sometimes a brief sketch helps...installing extra terminal strips helps...in a pinch, going up from the deck with a terminal on a bracket helps.
The chassis fabricator did require drawings. Seems they could not read my mind... 😉 They did some holes, I did some holes.
The hard part is considering the consequences of each part placement in terms of the dozens of constraints like heat, magnetic fields, electrical fields, service, de-bugging, noise, and especially the ground return nets. Unfortunately, this does not result in one of those super-neat production chassis of yore.
It is a prototype in a somewhat nicer-than-prototype chassis. Judy wanted a tube amp for her birthday 😳 She calls it a "toobie" 🙄.
David
P.S.
When it is completed, it can be shown in the tube photo section. ( If I make it, the 500VDC makes me nervous...ZAP!)
Reactions: wlowes
I used CAD to lay out the chassis. Then checked that all the parts fit on a printout. It was relatively easy to sketch out the wiring connections on the printout. When it was set, the CAD file drove a waterjet to cut the holes. After that assembly was pretty easy.
Reactions: astouffer
