Plethora of Pinjatas / SET P amp(s)
With temporary power supply, dual mono transformers on way. This will do to fire it up!
Only thing left is a CL 60 to ground the power supply to chassis. No CL60! I do have CL30, and I have an extra original power supply F5m kit, which has a couple smaller thermosistors and a larger green one.
Would either of those work in this chassis ground position? I'm figuring bigger, not smaller would be better. Hate to hold up fire up over a CL60 order!
Thanks, I need to order another pile of CL 60 anyway ...
Russellc
All ready to fire up first channel. For the DMM on the bias, should I hook up the dmm as in figure #1, or since this is "mini" XA 252,
I assume that figure #2 is good too? That's how I did it on XA 252.....Pic in a quick..
Russellc
1st channel now at 120 volts via variac. Bias is .95mV, about half, offsett 16 mV. See if sinks warm before increasing bias. Oh, greenie led came on of course
Few minutes later, sinks beginning to slightly warm, few more up to 120 mVish for more warming
Russellc
