If running directly out from the DAC to the phono sockets, and omitting the output capacitor (my pre-amp already has one), does one need to keep the 22k resistors on the phono sockets of the PS, or can those be omitted also?
Many thanks!
- John
Many thanks!
- John
Skipping the resistors
Hi John,
you can skip them .. just wire directly. I have a direct wired system as well as a filtered system and there is a small improvement in the direct sound. The resistor is part of the capacitor - resistor filter to stop low frequencies (below about 3 Hz) reaching the amplifier. If you don't need one then you don't need the other.
George
Many thanks!
- John
Hi John,
George
I had the the original ps1 but managed to knacker up the pcb. They are difficult to find in the UK. Could I buy one over from the states and then simply replace the internal power supply so that it would over here with the 240V supply?? i have a nicely modified Power supply that would do the trick!!
Excellent!
I managed to knacker the PCB when removing a mod chip and since then I cant get the CD to spin. I've done one or two small mods to my PS, the remote control mod will be next.
I have a spare PS1 PCB if you want it? The output leads are already wired in place, plus flying leads for an open/close TOC switch. It's just the PCB - no chassis, PSU etc.
- John
- John
Can you send me a PM with details about postage and how much you want for it!! Thanks in advance m8
For North America, the Playstation 1 models best suited for modification are Model SCPH-1001 and Model SCPH-5501. These both use the AKM 4309 DAC. I don't believe Model SCPH-7001 uses this DAC. It might have a CPU with an integrated DAC.
To modify Model SCPH-5501, you must install RCA jacks on the chassis as this model does not have any RCA jacks in stock form.
Thanks Rich,
the 7001 doesn't have RCAs either. I have a modded 1001 that works (some skipping) and thought I'd ask before tearing into this one. I re-calibrated all the voltages per Dogbreath so I might need a new laser. Any suggestions?
I've included BOMs from Mouser (Nichicon caps) and Digi-Key (Panasonic caps) depending on preference. I went with Mouser, because I wanted to try the Wima MKP10 caps on the AC input, but I am sure that the Epcos MKP caps are fine. Certainly, the Panasonic FC and FM caps would be good in this power supply. I still haven't installed the IXYS HEXFREDs, but that will be soon.
Mouser, SR670
Quantity Reference Part Supplier Supplier Part No.
4 D101, D102, D103, D104 IXYS DIODE FRED 600V 30A TO-247AD Mouser 747-DSEP30-06A
1 C101 Wima MKP10 Polypropylene Film Capacitors 400V .1uF 5% Mouser 505-M10.1/400/5
1 C104 Nichicon CS Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 220uF 200V 18X25 20% Mouser 647-UCS2D221MHD
1 C111 Nichicon KT Audio Electrolytic Capacitors 47uF 50V 20% Mouser 647-UKT1H470MED
1 C201 Nichicon KT Audio Electrolytic Capacitors 1000uF 25V 20% Mouser 647-UKT1E102MPD
1 C202 Nichicon KT Audio Electrolytic Capacitors 1000uF 16V 20% Mouser 647-UKT1C102MPD
1 C203 Nichicon KT Audio Electrolytic Capacitors 2200uF 16V 20% Mouser 647-UKT1C222MHD
1 C204 Nichicon KT Audio Electrolytic Capacitors 1000uF 6.3V 20% Mouser 647-UKT0J102MPD
1 IEC receptacle Furutech FI-10 (G) IEC Receptacle Sonic Craft Furutech FI-10 (G)
1 Chassis wire Furutech FP-314Ag Wire Sonic Craft Furutech FP-314Ag
Digi-Key, SR670
4 D101, D102, D103, D104 IXYS DIODE FRED 600V 30A TO-247AD Digi-Key DSEP30-06A-ND
1 C101 Epcos CAP .10UF 305VAC EMI SUPPRESSION Digi-Key 495-2319-ND
1 C104 Panasonic CAP 150UF 200V ELECT ED RADIAL Digi-Key P13520-ND
1 C111 Panasonic CAP 47UF 35V ELECT FC RADIAL Digi-Key P11232-ND
1 C201 Panasonic CAP 1200UF 16V ELECT FM RADIAL Digi-Key P12367-ND
1 C202 Panasonic CAP 680UF 16V ELECT FM RADIAL Digi-Key P12378-ND
1 C203 Panasonic CAP 2200UF 10V ELECT FM RADIAL Digi-Key P12357-ND
1 C204 Panasonic CAP 1200UF 10V ELECT FM RADIAL Digi-Key P12355-ND
Mouser, 1-473-380-1x
1 C001 Wima MKP10 Polypropylene Film Capacitors 400V .1uF 5% Mouser 505-M10.1/400/5
1 C003 Nichicon CS Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 220uF 200V 18X25 20% Mouser 647-UCS2D221MHD
1 C102 Nichicon KT Audio Electrolytic Capacitors 1000uF 25V 20% Mouser 647-UKT1E102MPD
1 C103 Nichicon KT Audio Electrolytic Capacitors 1000uF 25V 20% Mouser 647-UKT1E102MPD
1 C104 Nichicon KT Audio Electrolytic Capacitors 330uF 25V 20% Mouser 647-UKT1E331MPD
1 C105 Nichicon KT Audio Electrolytic Capacitors 1000uF 25V 20% Mouser 647-UKT1E102MPD
1 C107 Nichicon KT Audio Electrolytic Capacitors 1uF 50V 20% Mouser 647-UKT1H010MDD
Digi-Key, 1-473-380-1x
1 C001 Epcos CAP .10UF 305VAC EMI SUPPRESSION Digi-Key 495-2319-ND
1 C003 Panasonic CAP 150UF 200V ELECT ED RADIAL Digi-Key P13520-ND
1 C102 Panasonic CAP 680UF 25V ELECT FM RADIAL Digi-Key P12390-ND
1 C103 Panasonic CAP 680UF 25V ELECT FM RADIAL Digi-Key P12390-ND
1 C104 Panasonic CAP 330UF 25V ELECT FM RADIAL Digi-Key P12387-ND
1 C105 Panasonic CAP 470UF 25V ELECT FM RADIAL Digi-Key P12388-ND
1 C107 Panasonic CAP 1UF 50V ELECT FC RADIAL Mouser P10312-ND
I also intend to replace the cheap PVC-insulated DC power wires with Teflon-insulated Silver-plated Copper wires. I just found some break-away flat cable connectors that Mick Feuerbacher describes in his Web site.
To keep costs down I'm interested in re-capping my SMPS. Its a 240 UK model, the Powerpack version is 1-468-159-11 would these components work on that version of the powerpack or would I have to look for different components so they are to uk 240V. My knowledge of electronics is pretty crap! I'm trying to learn 😛
Hi.
Does anyone have the schematic for 1000/1/2 or 3? I would like to see how the A/V connector is fed and from where regarding the videosignal/s. On the ps2 you could get VGA if you had the linuxkit (which I have) or if you used some games (which I don't have and don't know more abt).
G'day all,
I just stumbled upon this thread after a search, as I've been using a PS3 as a source for a while now.
I see theres 2661 replies to this thread, I think I'll struggle to find the time to read these all. Any chance someone could give me a quick summary of the topic?
I can narrow it down. I'm just about to play a PS3 into a lavry da11. It's just a plane old spdif into the dac right? Are there upgrades you can make to a PS3 to improve audio or are the discussions in this thread along different lines?
Cheers, James
Cheers, James
Cheers, James
Yup.
G'day all,
Cheers, James
Its all about the PS1 not the PS3 2 complete and utterly different beasts!
I just picked up two 1002's for the fantastic price of £15. So the plan is to do the full Mike F/dogbreath.de mod to one of them, build a new casing, and add a 3"/4" LCD, and then compare it to the other, and then do something with the second, however, I have never done any circuitry building before in my life, so I have no idea where to get all the parts from (ie caps and resistors, pcb boards). I'm not stupid so i think i can manage this, however is it advised, I start with a few amp kits first?
Also, is the laser part of the reason these are so good, or is it better to replace them; because i was think of replacing it if it isn't, as at a store near where I live, the guy working there says he has many old marantz readers which are meant to be high quality, unfortunatly i cant tell you what they are (i cant remember), but will update you tomorrow, when I go there...
Many thanks in advance!
Alex
Alex
If it aint broke don't fix it!
The laser unit will either work or it won't. I believe that you can get replacement Sony units from the likes of ebay. However as PS1s are as cheap as chips, if the laser goes, just buy another PS1. The laser sled is different in the 5552 to the 1002.(you can mod a 5552 without the audio outs, you just have to add two phono sockets)
If you are going to do the MickF mods be aware that the pictures on his site are enlarged. In reality the parts to de-solder are minute and can be tricky if you have no de-soldering experience.
Forget the Marantz lasers unless you have a dead Marantz CD player.
Rob.
Rob.
- Digital Source
- Playstation as CD-player
