You should be happy keps! Congratulations. Now take it apart and do it all over again... just kidding 😁
Enjoy you work! I’d bet this is not your last build 😎
My HPA-1 Clone
- HF/DC Mains Filter
- Active Rectifier
- Muses Volume
- IR Control
- Balance
- Active Rectifier
- Muses Volume
- IR Control
- Balance
Good job Keps! You know you are addicted now right.../
My name is keps and I'm an audioholic..... Hello Keps!!! 🙂
@meldano My highest comeplement.... Lovely.
What are the inserts that slide into wall profiles slots? Are these some standard parts, or did you make them?
to soldersober
Hello soldersober,
do you mean the M3-nuts in the slot on top of the black side-profiles?
Greets
Dirk
Hello soldersober,
Greets
Dirk
Yes, are these just plain standard nuts? Can't see clearly from the photoHello soldersober,
Greets
Dirk
to soldersober
Yes, very normal M3-nuts - included in every Modushop - case - kit.
Greets
Dirk
Greets
Dirk
to Meldano
Hello Meldano,
I didn't regognize this on the pics. Good solution with the threaded metal stripes.
Cheers
Dirk
Hello Meldano,
Cheers
Dirk
2SK77B 50W SE Class A Monoblocks (Singing Bush)
I recently had the incredible fortune of acquiring a pair of the 2SK77B Tokin SITs. The clear choice was to build Nelson's 50W BAF SE Mu-follower amplifier, and I went with ZM's bullet-proof version of it, the Singing Bush. Here a few notes on the build itself:
- two individual monoblocks for a stereo pair
- Toroidy transformers with 48v secondary and a 15v secondary
- CRC smoothing - 47Kuf > 0.15R > 47Kuf
- I used rhthatcher's ground bridge board and inrush board (recommended)
- Wiring is all 14AWG PTFE from Apex Jr
- Big output cap is F&T 10Kuf 100V 105C
- Faceplates based on the recent Sony SE DIY amp; made with FrontPanelExpress
Thank you to Nelson and ZM for making these possible!!
@meldano
Very impressive build you made! If you ever do a GB for it, please let me know.
@codyt
Again, super impressed with your build quality and attention to detail!
Enjoy your builds!
Do
@codyt
Enjoy your builds!
Do
After the masters had their gems shown—woah, perfect, both are just perfect!—here‘s what I am finishing:
My Build of Wayne‘s Line Stage 18, back to be connected again!
Even though there’s still things amiss. (My stubbornness on those 4 (four!) knobs left me in the cold. What should I do with a fourth knob???
- Pictures of your diy Pass amplifier
