Photo Gallery
And the back:
It is thick (1/4") solid aluminum plate which I finished with a wire
brush then sanded down a bit. I found a company which sells ends
on Ebay (company name is 80/20) and something like this costs
about $25 shipped. This actually turned out to be a bit
of a pain, as normal fittings aren't designed for anything this thick.
I couldn't under-mount the tube sockets, for example, so KT-88
tubes look silly.
Baby Ongaku
Just finished my first tube build. It is Gordan Rankin's Baby Ongaku as a stereo rather than monoblocks. I used Magnequest ES-025 output transformers and a Hammond power trannie. The design was inspired by amps from Don Garber of Fi.
Cheers
Rick
717-2a3 amp
This a "clone" of the Yamamoto amp with cheap parts.
717 is the best driver i have used withe 2a3 and i have tried many! Maybe is the circuit not the tube, but who cares?
I'm finished trying circuits for the 2a3. This is it!!
Hi.
is that a shigaclone?
Yes. A heavy brassplatter, 4 springs and a housing+aluminium topplate.
I welded the covers of the transformers from rectangular steeltubes.
After putting the transformers in, I poured resin into the "cans".
The chassis is bend and welded 3mm aluminium. Sanded an finished with clear-coat.
Cheers, Michael
