Photo Gallery
I used my old cell phone's case it came in , i its crazy but you'll find the darndest things to put an amp in , it works well , and looks good i think ? :) .
I used 6cg7 as the inputs and 6922 as the outputs.
No, i got the original "broski" pcb, not that i'm affiliated , and or promote his boards over others , in fact i sent him several email afterwards asking some basic pointers and got no reply :dunno: , but i suppose thats why its called DIY :smash: , but he did send the pcm fast considering im on tha other side of the world.
Oh and the monitors are Fostex PM2 , they sound fantastic as they are , but with the preamp the music takes on a new character (smooth , sweet, detailed, yet fast and dynamic) ... i did have slight hum at first but sorted that by biasing the heater Ct (ac heaters), im just experimenting with a few output caps, to increase the bass a touch , it probably rolls off at around 80-100hz (becaue of the ipod) , but a 1uf should fix that , i would like it to start at around 30hz.
my last creation, a Single End amplifier with EL84;
What did you use for xfmer covers? Don`t like valve rectification?
I bought the molded plastic x-fomer covers at www.roehrentechnik.de where i also bought the transformers, i chose not to use a tuberectifier because of the powertransformers lack of windings for that purpose, i opted for solid state rectification with fast diodes and a lot of powersupplycaps.
Minimalistic outside, but surely not inside :cool:
Just a little "how-NOT-to" from my second project. This just looks too dangerous, so I HAD to take a picture :D
This is a stereo KT88 SE amp, built from Mikael Abdellah's schematics, waiting for its chassis. I'm using a very old Telefunken ECC85 in it right now, and I think I like it more than the 6N1P so far. The PSU is all MKP motor run caps and will be on a separate chassis due to the size (the largest transformer in the picture is not used, BTW). James OTs, Jensen copper coupling caps etc. etc. :)
planet10 said:
Do you have some detail on that... i have quite a few ECC85 in my junk box, including a whack of TFK.
I'll admit I don't know much about this, I just know the pinout is the same... I checked the max. ratings and popped it in without any modifications. Sounds pretty good to my ears. :)
I've seen audio amps using ECC85, but not many. Mine came from an old radio.
Rolf
Se3x6550
Single ended triode/ultra linear mono amplifiers based on 3 x 6550 power tubes. Low distortion, medium power, shunt feedback design.
At the work bench:
Night view:
Some key figures:
- Single ended, no global feedback.
- Bandwidth (Po=10W): Triode: <10Hz-70kHz (-3dB), UL: <10Hz-75kHz (-3dB)
- Max power output rms: Triode: 24W, UL: 45W
- Distortion (Po=10W): Triode: 0.6%, UL: 0.3%
- Damping factor: Triode: 6.9, UL: 5.3
Distortion pattern 400Hz sine, Po=10W
Square wave 10kHz, Po=10W
Custom made transformers and chokes by Sowter.
Jan E Veiset
NO-6600
My Hybrid
Well, i have finally finished my hybrid ( http://www.diyaudio.com/forums/showthread.php?threadid=78576 ), now i only need to get a decent PSU for it.
The enclosure is from a 3,5" HDD to USB externall case.
