If it moves - don't fondle it ...It's great until you want to modify it!
NICE!
I like that there are boards out there that simplifies construction. I have a board for a slightly simpler EL84-PP, but due to Summer, I have everything stored away and I cannot directly get the correct components to finish the amp, but will bring them home from USA in September.
If looking for a generic amplifier design, boards and even kits are available on eBay, Amazon, AliExpress and elsewhere. And often the prices are fully accaptable.
PS. I will use BLUE leds in my amp as that upsets people ...
alex mm,
Most P-P EL84 amps are cathode bias. Your design above looks like fixed bias.
If so, what bias voltage are you designing for? Or will you test for optimum value?
Thx,
Jim
Thx,
Jim
I have just completed a new (pre world war two technology) valve amplifier for my computer sound system. The TRIMAX power transformer is typical of the type used in the late 1930's. I don't know the transformers year of manufacture, the company closed in 1963. The transformer used is not the most suitable for the task, it did however paint up nicely and I was able to save the TRIMAX logo and ripple paint finish. The large valves are 807A's, I used them because they look cool, a modern power cord and connectors were used as the amplifier has to be practical. The ripple paint finish was for the old world look. Triode connected 807's as low power O.K for my computer speakers.
WOW!!! How did you get everything in place? A shoehorn?
Guess the top displays show bias (??), but the bottom bargraphs?
That's tight...
I'm into real estate efficiency- applause.
That focus could cause noise, which in itself is another challenge. Then heat dissipation, another layout conundrum
But for those who choose this path... hats off... the next level of layout design, imo
Jim
Jim
Does these tubes give THAT amount of filament light??
Can't help it, but i find leds below tubes cheesy. Especially green ones in mcintosh amps.
TonyTecson
What core geometry is that you've laid down......?
my 300b build #2
three interleaved cores, gapping is as per usual...you have good eyes...TonyTecson
- Tubes / Valves
- Photo Gallery
