If the drivers follows LR4 slopes then the lower frequency driver is one period behind the higher frequency driver in the time domain, that delay.
The reverse null test just shows that the drivers are in phase... but there are infinite points where this happens, spaced 360°.
No delay involved here (we're speaking of an idealized XO here, "drivers" with flat response and no offset of acoustical centers).
Thank you for your clear and simple explanation. "Basic" is definitely what I need.
So if we use a fourth order crossover between two drivers, this implies that the sound from the drivers will be "out of sync" by a small amount due to the phase lag.
Thus if we have a 3-way speaker with drivers whose axes are magically co-incident on the baffle and we use LR4 crossovers at, say, 333 Hz and 3,333 Hz, we should ideally add a 0.33 ms delay to the mid and a further 0.03 ms delay to the tweeter in addition to their respective acoustic delays. These delays might not be constant across each crossover range, but it would a lot better than nothing. Does this make sense or am I talking nonsense?
It might be obvious by now that I'm trying to learn about the implications of phase at crossover frequencies. I'm currently working on a 3-way design and discovered that at one particular set of delays the sound suddenly snapped into focus. The difference wasn't subtle. This was with a DSP system. I appreciate that this forum is for loudspeakers with crossovers, but the problem must surely exist with both approaches. I'm trying to figure out the best way to deal with this when choosing crossover points.
Thanks again,
emdubya
You're welcome!
In my usual haste I didn't take the time to work through it, just answered your Q, but using a 1 kHz XO led you to make a false assumption. For 333 Hz the delay is much longer since the WLs expand exponentially [1/f], so..........
~13543"-sec/333 = ~40.67"
~13543"/1000 = ~13.54"
~40.67"/~13.54" = ~3 ms ............. and ~0.3 ms for the tweeter.
Or simply 1/f = ms.
This assumes a coincident [point source] system, so for a typical multi-way there's the phase angle to consider.
Back when I learned this stuff you either did mass quantities of distance measurements and worked it out with a slide rule or then very expensive electronic calculators for arrays or normally for individual speakers just did the physical calcs, locations, then reversed the HF polarity to find the deepest null, screwed it down tight and switched it back to positive and it was what it was and since it was usually well inside the pioneer's 1/4 WL rule it was seamless at the measurement/listening area.
Re modern DSP, I've only just been exposed to it recently and was mightily impressed with what it could do to convert a horrible room, multi-way system into a 'HIFI' reproduction system, though with the downside that it was by far the least entertaining Altec horn based system I've ever auditioned, but the DIY and HIFI oriented 'hornies' really liked it to the point that some declared it maybe the best Altec based system to date, so for all its trickery, I lost a lot of interest in it for personal use.
That said, a local DIYer with a very large all horn 20-20 kHz multi-way system in a fairly large, open format room TD'd and EQ'd flat claimed it impressive but in discussions it sounded like the various delays were off, so he removed all EQ, unwrapped the phase of each, TD'd them till he wound up with a flat phase and amplitude response from 20-20 kHz, i.e. can near enough replicate a square wave = accurately reproduce a sound signal, with the most interesting part [to me] being that he didn't have to use any EQ, where initially he needed mass quantities of it, so back liking/wanting DSP. 😉
Now he's trying to integrate two separate REL infra-bass sub systems, which I fear will be his undoing even with all the electronic didgeridoo. Guess I need to get an update and hopefully he'll publish his 'adventures' in audio system design once 'close enough' to perfection.
GM
Ah, I see where the problem is. This statement is plain wrong, where did you get that from?If the drivers follows LR4 slopes then the lower frequency driver is one period behind the higher frequency driver in the time domain, that delay.
A LR4 XO has the same identical phase (and thus group delay) response for woofer and tweeter, which means the drivers are in "total sync"... and my experiment will just show this and confirms theory.
But moving the HF 1ms behind the LF works only at 1kHz. Right?
Correct, just a starting point to manually time align a speaker.
GM
GM
But you don't want to time align the drivers because of crossover delay (1 period for LR4), you want to time align because the acoustical center of the drivers are ususally in different locations hence different distance to the listeing/measuring spot.
Phisically moving the higher frequency driver to compensate the delay caused by the crossover can work at one specific frequency but causes problems at other frequencies.
360 degree out phase (LR4) is not equal to 0 phase difference in the time domain to me (in the phase domain it is equal ofc), because the 360 degree out of phase response needs time to be "completed" , hence one cycle delay. Correct me i am wrong.
From Hypex HFD manual for example:
"Linkwitz-Riley
For best crossover filter results, Linkwitz-Riley filters are a good choice. They come
2nd, 4thand 8th
only in even-order, so like
etc. The 2nd
order filter will give you a phase
shift of 180 degrees. Best is to use the 4th
order Linkwitz-Riley, which will result in 360
degrees phase shift. That way, the low and high output appear in phase (although the
low output will have a one-period delay)."
Btw i think it's nothing wrong with LR2 where one driver needs reversed polarity compared to the other driver for phase matching.
Moreover LR2 have better time domain response compared to LR4 because it has only half cycle delay, therefore, the polarity of one drive must be reversed.
"Linkwitz-Riley
2nd, 4thand 8th
etc. The 2nd
It is better that you don't use the term 'delay' when talking about phase. They are not the same.I am not mentioned *group delay*. If the delay is not one cycle for LR4 slopes then the reverse polarity test doesn't show that deep notch called reverse null.
This is audiophile conjecture. If I read this in the manual, I'd begin regretting buying the product.Best is to use the 4th
Yes, I may have used the term 'delay' incorrectly.It is better that you don't use the term 'delay' when talking about phase. They are not the same.
And if the manual trying to suggest what's the "best" choice of crossover that doesn't mean that's for a bad product. That means it's not the most correct manual and nothing more.
So, for LR4 crossover slopes, it's one cycle delay for every frequency for the lower frequency driver, that's correct i think.
That was an excellent read. I almost understood a fair bit of it!
Back when I learned this stuff you either did mass quantities of distance measurements and worked it out with a slide rule or then very expensive electronic calculators...
....in discussions it sounded like the various delays were off, so he removed all EQ, unwrapped the phase of each, TD'd them till he wound up with a flat phase and amplitude response
GM
It sounds like we're about the same vintage.
That's exactly what I have experienced - audible timing differences.
Thank you for the illuminating discussion.
My question arose when I discovered that, especially with one particular piece of music, it sounded like the band members were deliberately trying play off-beat. It was horrible. However, both my DSP delays were well under 1 ms, so I was trying to figure out what was going on by understanding why those particular empirical delays had produced nulls when the mid was inverted and yet the music was so off-beat.
To me, the most likely answer was that there are an infinite number of delays that will produce nulls, but that they are infinite integers of periods apart. So how do I know that I have the right one? It now seems that this isn't the case, although I could still be off to a limited extent.
Rod Elliott alludes to the phenomenon of "slow bass", but doesn't elaborate much. I'm wondering whether that was what I heard from my ported box.
Since posing the question, I have been able to measure the acoustic delays to a reasonable first approximation. However, these produce only shallow nulls with the mid inverted, and tweaking them by a few hundredths of a millisecond either side makes the nulls even shallower. Clearly there's something else going on that I need to account for. I hope to get back to this later today or tomorrow.
I appreciate the stimulating discussion!
If the reverse null are not deepens with fine adjustment, then one or more of your driver's acoustical slopes doesn't follow the desired LR responses on the measured axis.
Or your fine adjustment is not fine enough.
...meaning that the driver's natural roll-off is steeper than the filter's roll-off?
No, the final acoustical slope of a driver, which come from the finished, crossovered speaker. That's what matter.
It doesn't matter what electrical slope you use.
OK, so the crossovered slope isn't what I expected it to be with LR4. How do I fix that...do I move the XO point around until it goes away, or try different XO types?
- Phase and time delay
