PeeCeeBee
Hello
Hi Shaan
greetings tried your 2 pair one EXCELLENT SOUND ;)
warm regards
Andrew
yasss ,thanks shaan .
planning to change feedback cap with better one . its worth to do ? now im on panasonic fc .
fine gold should be ok ?
if it worth will be on my list when sourcing dcb1 parts :D
If you feel good with the audio-grade capacitors then by all means get them.
I can't assure you whether the audio-grade caps are worth it or not but last couple of days I have been doing comparison between different 2200uF caps, namely Nippon-chemicon KZE(my default option), Panasonic FM and Elna RJG.
Result - No audible difference whatsoever between the three models.
I updated my Amp to use Nichicon FG 2200uF/6.3V in parallel with 0.22uF X2 caps and noticed a difference in all three sections (high, mids and bass). In my listening test it has became more transparent. :D
I've built the V3 with all panasonic cap. But no audible difference at all
Both statements are valid from subjective point of view. We all hear differently... :(
