PeeCeeBee V4H GB
I got Fairchild KSE340/350 pairs from eBay. The 340s are short-legged :irked:
Any idea on how to mount it in this supposed config.?
Maybe I could raise them with 2mm aluminum?
How hot they get anyways?
Hi Bassivus
The 340s look fishy. So be careful. They dissipate about a watt each under load so you may be able to mount them on the front and cool them with small heatsinks.
But the 340s do give me a bad feeling. The legs look wrong somehow, apart from the fact that these are cut off already!
Hi Bassivus
I have inspected 340s with magnifier and it is never installed and production short-legged for sure! Also it measures fine.
I have bought it from eBay but, reputable UK seller. I truly believe that this seller is legit.
Hi Shaan,
I am using MJE340/350 instead, can I mount them in front with individual heatsinks too?
Will make my install easier.
I think you can but please note that I have never used them mounted on front with their own heatsinks, so cannot guarantee thermal stability this way.
:up::)
