PeeCeeBee V4H GB
Hi Shaan, from testing my KSE transistors, the entire N-P-N lot of 20 transistor is HFE value ~88 & the P-N-P lot of 20 transistors is HFE value 179...not sure if they are fit for Q9,Q10 as they are expected to be matched...can try BD series here?
Sorry may have missed somewhere, but from the schematic the R27-28 & R29-R30 pairs don't seem to be in sync...the rest of the schematic is perfectly symmetrical...hope this is by design...
R27 - 330R
R28 - 220R
R29 - 330R
R30 - 220R
please confirm
found perfect matches in BD series - BD139/BD140 - 2 pairs (HFE 132, 134)
:up:🙂
R27 - 330R
R28 - 220R
R29 - 330R
R30 - 220R
please confirm
It's by design so no worries.
Sorry to hear about trouble with shipping, but no worries, I have plenty of time.
I found a transformer for cheap with 4x42v, but im uncertain of the grounding layout. I've attached a sketch, but uncertain if the RCA will cause a ground loop. Any suggestions?
I was too late for the PSU, so im using diyaudios protection boards. Had some fun learning autocad and drew my build. Dissipante 3U 300mm. Looking forward to actually build it 😀
Packets moving now.
I always suggest a star ground created as far as possible from the transformer. Every ground connection except speaker return connected to star, speaker return connected to capacitor bank 0V.
It is hard to tell as it depends on many factor. Best to try your config and see.
