Pearl Two
I have -6.37 @ the test pin . It will not move . All parts were tested and P1 was removed and checked ..... V @ Q4 & Q5 gates are stable in the 30mV range .
Is the fact that I'm using the 2.2k @ Q2 the problem ... ? I only have 3 ZVP so I want to be sure as I can be before I plug it in .
Rich
With the 2K2 resistor you are indeed unable to modulate DC offset to your needs. Because resistor has only 2 pins and no gate (command) pin 😀
Try the ZVP in. I have some spares that I could send to you, in case you run out of stock 😉
Best,
nAr
