I have -6.37 @ the test pin . It will not move . All parts were tested and P1 was removed and checked ..... V @ Q4 & Q5 gates are stable in the 30mV range .
Is the fact that I'm using the 2.2k @ Q2 the problem ... ? I only have 3 ZVP so I want to be sure as I can be before I plug it in .
Rich
Rich
Check around Q11 or Q11 itself. It is its job to bring down voltage on test point P1.
changed Q11 and no change
S= 23.76
G= 22.36
D= 22.85
I think its somewhere else ...
Hi 6 ,
I have a fully working board ... just one to go !
Check voltages on R29 then?changed Q11 and no change
S= 23.76
G= 22.36
D= 22.85
And Canada one too
nAr
I would take a bet that Pierre is French Canadian... hey , I could be wrong . Its something about his name
That isn't easy to do on R29.
Thanks Wayne ,
I guess a job is out of the question
its easy cus I'm special ! I had this problem before .... When I used a 1 amp fuse at the very beginning.
I may order a new board in the new year .... I just replaced the pos reg !
Any opinions welcome ? New board , new parts and start again ?
Rich
- Pearl Two
