Pearl 3 Burning Amp 2023
Congratulaion 😍
Isn´t it nice, when it´s that easy 😉
Enjoy your Pearl-3.
Unfortunately, my own build keeps being postponed.
Was supposed to finish it this weekend. Had ordered the Schurter AC inlet, and forgot to read the full comment.
It came without the fuse holder 😡
Same with the cable gland for the PSU. It came without the nut. 😡
I need to remember to read the full specs when ordering, Specially looking for the comment
" Has to be ordered separately"..........but who the hell sells a car without weels? 🤣
Going through my stash of components, and out of 7915.
Went through all my friends within a 10 mile radius........ no go, so what should have been a listening session today ended
up with nothing.
Well........ tomorrow the stores are open again 😊
You do have to order the fuse drawer separately, but the cable gland should have it, mine did.
Reactions: Boydk
Thanks for the link, but a little too late.
And besides, it doesn´t fit the cutout on Gianluca´s enclosure.
I know, it´s expensive, but (at least here in Denmark) everywhere I looked, the inlets available were either not
tall enough or wide enough for the cutout. I wanted it to look as nice as it suposedly plays, so Schurter it was 👍
Just wish, they would stop ripping people off by selling products with "missing" parts 🤣
For the PS enclosure I had to be creative as it was impossible to find at toroidal at 26.3mm height. So with the shortest possible board stand offs and adding washers below the top lid, just to bring it aligned with the front plate, I managed to fit a 37.5mm one.
No challenges, no fun. 😉
@Boydk Take 5mm stand-offs, trim them for 1 mm, then use 2-3mm washers or one hex nut between side panel and lid, and you will have the "enormous" amount of 1mm clearance between transformer and lid.
It just came to mind 🤣 🤣
I´m not using the "Group by" PSU. So the transformer will be mounted directly in the enclosure.
I took another approach. 2 x 18 volt torodial into @sachu888 PSU boards (had a couple on the shelf).
Adjust these to +- 19 volt DC out, and then into the Pearl-3. Gives the 7815/7915 4 volts above the regulated output,
which should be plenty. My guess would be even lower noise floor. We´ll see, how this pans out😉
@Boydk: Let me know how the 19 vdc works in the noise arena. The flexreg transformers from Randy can be adjusted from 14 to 22 vdc and if there is an advantage to 19 over 18 (or even higher) it is easy to accomodate.
Tried to go with a 1U enclosure on my first build but gave it up because of the Amphenol circ connector; it is a monster. But it allows for six 14 awg, finely stranded wires that will pass anything from 120vac to 20+vdc. Building these umbilicals is a pain but you do end up with 4 feet lines that will last forever.
The first P3 build I used two of the umbilical positions to pass the on/off switch from the PSU to the circuit board, thinking that the switch would be more convenient there and allow for the psu to be placed 4 feet away in the back. Does work and doesn't seem to add much noise (if any). For the dual psu build needed all 6 of the Amphenol positions for the two 18 vdc +/- lines and it has been, overall, better.
I would reconsider that setup. If I understand you correctly, you are passing a direct connection to line voltage to another chassis. Unless you are exactly correct with your safety grounding there are many situation where that could be lethal without any warning. I also believe even posting about such a design is against the posting guidelines. At minimum you would need an isolation transformer at the AC input to the PSU and still hope you have it wired correctly with all panels connected properly. Use this instead https://www.diyaudio.com/community/...ains-relay-includes-soft-start-h9kpxg.354971/
Is the 1A (lowest filter range - 20db at 10khz) two stage filter DD14 (3-103-776) going to have any real benefit over the single stage DD12 (DD12.1121.111)?
There's no need for a 10A PEM right (DD12.9111.111)? I presume 1A is more than enough, but I'm often wrong.
I noticed while shopping for parts that Schurter offers a line of two-stage filtered power entry modules, DD14 series, in the same form factor as the recommended single-stage module DD12.9111.111. They're a a bit more expensive but offer a good increase in RF rejection. Possibly overkill, but can't hurt. I went with 3-103-776 (don't forget the matching fuse drawer 4301.1401, which differs from the fuse drawer p/n for the DD12), and can confirm that it fits the chassis perfectly. Note that Mouser's product page shows the wrong photo for it - the actual product is "style A" per the catalog.
https://www.mouser.com/ProductDetail/Schurter/3-103-776
https://www.mouser.com/ProductDetail/Schurter/4301.1401
Reactions: Toys4Boys
I am pretty sure there must be a way of using the hollow legs of an OPA socket that are then soldered on the board in place of the load resistor legs, and to use them so you can insert whatever load resistor you fancy into them.
You could either leave things like that with your favourite load resistor(s)... or for purist seeking for the best possible contact once the prefered load resistor is chosen, taking the socket legs out and solder the said fav resistor definitely in place...
Having said that it isn't that usual to change the load for MM, but then if you really want it that could be a way of doing it while having it reversible...
Just thinking out loud
Claude
Reactions: Craigl59
