PC becomes very slow to respond
I installed the Motherboard drivers disc.
That added ~1GB of files to the C: drive, now up to 13GB
Full AMD MB drivers are <20MB , Full Intel about the same.
You most likely installed an included disk , which will install everything
but the kitchen sink ! 😀
The only "bloated" driver packages I've seen are the new NVIDIA and
ATI video packages.
ATI catalyst and geforce are 286MB. Installs as @ 100mb (drivers only).
Creative is also full of b$ , 250MB.
My new Xonar sound card = 23MB ! Cool.
My Nvidia video , xonar sound , and motherboard are 125MB total.
You CAN go to the actual manufacturer and download JUST a driver
package , usually much smaller.
An example is my HP (p1005) printer. It's disk (with bundled stuff) will install
250MB easy. Just the HP USB drivers (and printer control panel) from
the HP site is a 30MB install - still with full functionality.
Drivers from the site will usually be more bug free (updated) from
the original disk that accompanies the hardware.
OS
I un-ticked Chrome. But it installed that anyway.
So I went straight back in and un-installed Chrome.
Just remembered I did an MS defrag before MS Backup.
Could defrag have gone wrong and duplicated files and not deleted them?
Ost,
you're up early, or have you been out on the town and not got to bed yet?
the first Backup is a .vdh file @ 11GB
Asked for search of C: *.vdh and no results
but search also returns no results for E: even though I found it there
At the moment I have not downloaded any external programs.
nor done any Win7 updates.
Have you manually clicked your way through the C drive to see if anything odd is there or any obviously large folders ?
I am maybe half way through C: It has a lot of folders inside folders.
I just noticed a new message in that flag symbol in the bottom right corner.
It gave two messages.
One about backup.
It offered two options to check Backup or to run backup again.
I did check and it is going through a long HDD intensive routine with a blank screen.
Maybe it was backup that went wrong and added 25GB of files to my 40GB drive !
treesize is reporting C:
40.9GB C:\
_ 26.1GB [4files]
__ 14.9GB pagefile.sys
__ 11.2GB hiberfil.sys
__ 376.0KB bootmgr
__ 8.0KB BOOTSECT.BAK
_12.8GB Windows
__ and all the window files
and it also tells me that backup of 6th still exists on E; but they are only 55MB and 50MB
Have you a lot of RAM ?
Hibernate - Change Size of hiberfil.sys File - Windows 7 Help Forums
If you don't use hibernate then you can delete the hibernation file via disk clean (I seem to recall). You can always recreate it again if needed.
The same really applies to the page file. This is an area on the HDD that is used automatically when there isn't enough RAM. I think its set at around 1.5 times the RAM capacity. You can reduce it though.
windows - How do I decrease the size of the page file? - Super User
Yes, I changed the memory from 1off 4GB to 2off 8GB = 16GB.
I have got hibernate to OFF.
I have sleep to ON
that was the way the power settings were as default.
You need to delete the Hibernate file by running the command prompt in the above link.
3. To Turn Off Hibernate
NOTE: If you disabled hibernate using OPTION 1, 2, or 3 above, then there's no need to do this since Hibernate after and Allow hybrid sleep will no longer be listed in your power options.
A) Open the Advanced Power Plan Settings for your power plan, and expand Sleep. (see screenshot below step 4)
B) Under Hibernate after, set the Setting (Minutes) to Never. (see screenshot below step 4)
C) Under Allow hybrid sleep, set Setting to Off. (see screenshot below step 4)
As far as I remember hibernate is set to NEVER.
I will check
Sleep
. Sleep after _ Never
. Allow hybrid sleep _ On
. Hibernate after _ Never
. Allow wake timers _ Enable
I will turn hybrid sleep to Off.
Do I now delete the hiberfil file?
or will the system delete now that the setting is changed?
Treesize says the hiberfil is still same size.
Tried a restart in case it needed that to remove the hiberfil file.
It is still there.
Tried to delete from treesize (as administrator) and it came back can't because it is in use by another program.
How do I delete the now redundant 11GB hiberfil.sys file
The page file is normally managed automatically and by default sets at 1.5 times the RAM capacity.
The page file is for when RAM runs out and the operating system needs somewhere else to use temporarily. I suppose the basis is that if you fit 16Gb RAM you have done so with a view to using it and so the extra overflow of the page file is sized accordingly.
I doubt you ever even approach those limits tbh. I'm running 2Gb with Vista and less than 50% of RAM is in use even with many tabs open. Unused RAM (as in empty) isn't serving any purpose. The idea of RAM is that it has all that is needed loaded into it for instant access without using the HDD.
I'd set the page file to say 4Gb.
To Disable Hibernate
NOTE: This step will disable hibernation, delete the hiberfil.sys file, and remove the Allow hybrid sleep and Hibernate after Power Options under Sleep. This will also disable fast startup in Windows 8.
A) In the elevated command prompt, copy and paste the command below, and press Enter. (see screenshot below)
powercfg -h on
My cmp prompt comes on as
C:\Users\default.FM2_16GB>
How do I change that to C:\windows\system32> as shown in the pic in your link?
