only one install is showing
Repair or fresh install?
Fresh install - but read my previous post first.
Took me a while to read most of the 7solutions and then to type the first.
When do I see "Setup is inspecting your computer's hardware configuration" message is displayed. ?
The bottom of the screen is white and messages appear there stating what is happening.
Is that where I should look? It scrolls through them pretty fast !
This motherboard is an AMD FM2A58M-VG3+ R2.0
The processor box says AMD A4 5300 Dual Core Processor
Does that mean I don't tick the "Standard PC" option for single processor?
I don't know much about this.Method 1: Specify the Hardware Abstraction Layer (HAL)
Use this method first to try to resolve the Stop error message.
During the installation startup, press F5 when the "Setup is inspecting your computer's hardware configuration" message is displayed.
When you are prompted, make sure that you specify the correct computer type and Hardware Abstraction Layer (HAL). For example, if you have a single processor, specify the "Standard PC" HAL.
Try to reinstall Windows XP.
If this resolves the Stop error message and you successfully install Windows XP, you are finished.
Yes. I'm sure you have time to press F5 while it is scrolling.Took me a while to read most of the 7solutions and then to type the first.I don't know much about this.
A dual core processor is still a single processor on the mother board.This motherboard is an AMD FM2A58M-VG3+ R2.0
I did not see inspecting hardware message.
It STOPped at the same IRQL
Should I go straight to bios change?
Method 2: Turn off features in CMOS settings
Use this method when method 1 does not resolve the Stop error message.
Turn off all the following features in the CMOS settings of your computer. For instructions, see the hardware documentation or contact the manufacturer.
All caching, including L2, BIOS, internal/external, and writeback caching on disk controllers
All shadowing
Plug and Play
Any BIOS-based virus protection feature
b. Try to reinstall Windows XP.
If this resolves the Stop error message, go to step c.
If this does not resolve the Stop error message, go to method 3.
c. Try to isolate which feature is causing the error. To do this, re-enable each of these features one at a time, and then restart your computer after you re-enable each feature.
d. If you identify a problem feature, disable or remove it and contact the manufacturer to try to resolve the issue.
If this does not isolate a problem with a CMOS setting, but this does resolve the Stop error message and you can start your computer normally, it may be that a setting was preventing the installation. If this is the case, turn on the setting after you install Windows XP, you are finished.
It is very unlikely for that to be a sufficient amount of space for XP + Win7 upgrade version + Win7 updates.. . . and install MS apps in the 20GB C: drive?
Again I suggest 120GB drive C:
Where are you up to ? Have you got XP on the drive you intend to put W7 on ?
A clean XP install should only occupy around 2 or 3gb as far as I recall.
XP install is hitting a STOP.
see posts377 & 398 post393 is what seems to have bypassed the post377 STOP.
But I can't confirm it completely solved the problem.
That's true enough, however making the initial partition small means Windows can not put unmovable installation files 'out into space', a problem if you want to shrink the partition down. Keep it small initially until W7 is installed, then expand the partition to the size you want.
see posts377 & 398
OK, I'll have a read through it all a little later although I can't immediately think of anything for this.
Well having read it all I'm no the wiser on offering a solution for this. It does appear to be hardware related.
Do you have the HDD that originally had XP on it ? If so, does it still have a working and validated XP install on it ?
Yes. The very old 320GB HDD is sitting almost idle on this present PC as drive E.
But it is an IDE/Pata HDD. This rebuilt PC only has SATA/USB connections.
If I disconnect my 1GB HDD and boot up this PC it starts in XP from that HDD.
And yes, it was validated by MS but about 5 or more years ago.
I can't recall the details, but I have a feeling it was an OEM windows install, without any Windows disk, just a drivers disc
I have the CDR disc and I am guessing it is a back up I made at the time of purchase of the fully built PC.
The white paper envelope has the product key on it.
Shame I did not do the same for the Win7 upgrade DVD that I bought.
You can determine if its an OEM by this,
To determine whether you have an OEM installation of Windows, follow these steps:
Click Start, and then click Control Panel.
Click Performance and Maintenance, and then click System.
Click the General tab.
Locate the number that is displayed under Registered to.
This number typically contains 20 digits. If digits 6, 7, and 8 contain the letters "OEM", you have an OEM installation of Windows.
For example, the following sample Product ID number indicates an OEM installation:
12345-OEM-6789098-76543
An OEM install is only valid on the original PC it was installed on.
You can check if its activated,
Navigate through Start > All Programs > Accessories > System Tools and click Activate Windows. A window will open that displays the activation status of the XP installation.
I'm just having second thoughts on what I was going to suggest... which was to go down the 'image drive' route and then restore it back to the drive you wish to use. Second thoughts because the XP image would have all drivers for the old hardware as part of its configuration.
If your XP is an OEM then that could be another stumbling block if it fails to activate due to to many changes to the system.
I honestly don't know what to suggest to you, I just think you are going to have to try a few options before throwing the towel in and trying to get a new W7 license key and disc.
Not sure this is related to what you guys are doing but is there any chance this has left a door open for someone to invade Andrew's computer? I have received an Andrew email that was obviously not from him.
My rebuilt PC has not been connected to the internet. By cable.
Is there a chance it could have connected by WiFi without me knowing?
That's very odd Cal.
To connect via WiFi would need Andrew to input the router details and router pass key.
It seems to be a different issue.
When Cal first alerted me, I thought it was my DIYaudio account that had been hacked.
Cal thinks it is my Google Email (Gmail.com) account that has been hacked.
I have changed some passwords and giving up for tonight.
I'll see any new suggestions tomorrow.
Only the install that is 'active' and in use could connect or could be set up to connect.
Your clean installs would not have had any user data added.
And I can see your reply to Cal... Gmail ! Coincidence with all this going on ? Could be I suppose.
Same for me too. Been one of those days.
Email is generally in the cloud these days. W7 has no native e-mail client.
A clean install on a new W7 PC would not know anything about Andrew
(or his accounts).
Gmail ! Has a mind of it's own (skynet). My Yahoo was hijacked once ,
yahoo made me reset my password 3 times. Only the current super-strong
(upper/lowercase ##'s and symbols) password has held.
My yahoo account fired off emails to all my DIYA buddies 3 years ago.
My email has always been the biggest of my security problems , luckily
they scan my attachments well.
OS
(or his accounts).
OS
- General Interest
- Everything Else
- PC becomes very slow to respond
