PC becomes very slow to respond
Is it possible that the rebuild is too modern for the way XP expects to see the mechanical set up?
Or that the 4GB memory is too big for XP or some other XP incompatibility between XP and Win7?
These two HDD are the 750GB that were never used.
One got used to try to double install Win7.
The other one in it's antistatic wrapping is still unused.
I'm running short on time today...
Thinking aloud,
Could you install XP on the/or a drive that is compatible, make an image of the validated XP install and move it somewhere safe (an external drive) and then fit the new drive, this time using and running the backup program from a bootable CD or stick to restore XP onto the new blank drive fitted to the PC.
http://www.backup-utility.com/features/system-restore-from-disc.html
I THINK that XP does not have the SATA controller driver in the installation CD and hence the error.
I also think if you hit F6 during the installation process it will look for a driver on the FLOPPY drive - can you try that out [hitting F6 when it asks you to] and see what it asks for?
Another option that MAY work is to identify the SATA controller, slipstream XP to include the driver for this controller and install via the slipstreamed disk.
OK, I found this and this may be worth trying:
It seems it may work if we turn your SATA disk controller into ATA compatible mode.
Go into your BIOS. In the Advanced section there MAY be an entry "SATA Controller" with it being enabled. Disable it. This turns it into IDE mode. Save settings.
Try installing XP now.
Found it in Advanced\Storage Configuration
SATA controller(s): already set to Enabled
Changed SATA mode to IDE (three options IDE, RAID, AHCI where it was set).
SATA IDE combined mode is still set to Enabled
Hard Disk S.M.A.R.T. is set to disabled.
Save and exit.
Install is starting.
Deleted all the old partitions from Win7
created a new 20480MB partition (hopefully that will be 20GB)
selected format partition.
Copying files nearly complete
OK so far.
Windows screen is up and second part is installing.
Says it will take ~39minutes !
Another STOP
A problem has been detected and Windows has been shut down to prevent damage to your computer.
IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
I will shut down and start again
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical information:
**STOP: 0x0000000A (0x00000010, 0x00000002, 0x00000000, 0x8051AA58)
Beginning dump of physical memory
Physical memory dump complete
Contact your system administrator or technical support group for further assistance.
could the 20GB partition be too small for the first install? The minimum offered stated 0MB
Windows XP Home Edition Setup
If one of the following Windows XP installations is damaged, Setup can try to repair it.
Use the UP and DOWN ARROW keys to select an installation.
> To repair the selected Windows XP installation, press R.
> To continue installing a fresh copy of Windows XP without repairing, press ESC.
C:\WINDOWS Microsoft Windows XP Home Edition"
only one install is showing
Repair or fresh install?
No, it's not the partition. See this - https://support.microsoft.com/en-us/kb/314063
Go to the section - "Error occurs during the installation of Windows XP". There are 2 methods to try to fix this error. Please try them one after another. The second method involves going into the BIOS and turning off features. Before you turn off any settings - please note down what they were originally set at before you turn them off.
