Pass HPA-1, what do we know?
Hi genrg,
I matched the k170 to j74 to about 10%.
Most of the characteristic 2 harmonic is due to lower feedback rather than fet matching. You can increase feedback and get lower distortion but the sound seems to suffer.
Contrary to popular belief I did not intentionally design 2nd harmonic into the HPA-1 but what let listening decide what the amount feedback were set at.
Also, which might surprise a lot of people, is my main reference for the sonic character were electrostatic speakers and not headphones also the unit had to sound great as a preamp. When these were satisfied did I start to use headphones.........probably a different way of doing things but it worked for me. For a reference I also used a moth 2A3 tube amplifier.🙂 Please no flames.
Regards,
Jam
New schematic with fixes:
1) Corrected the BJT orientation that @RobLK found.
2) Implemented @MarkJohnson's suggestions regarding grounding non-active outputs.
3) Added comments regarding control logic.
Jeff.
Hello Jeff,
I was getting ready to order the PCB for my version and I noticed that R11 on your schematic is 332 but R41 on the other channel is 475. Is that a typo? If so, what is the correct value? Any other changes or updates?
Huh. That's a typo.
It shouldn't matter which you use though as there should be plenty of adjustment for the offset in the pot. FWIW, my LTSpice file shows 330, so that's a better guess as to what will center the pot.
No other updates.
Jeff.
Cheers!
Actaully Vader is partial to a White Russian.
For you DIY'ers out there
INGREDIENTS
2 oz. vodka
2 oz. coffee liqueur
2 oz. heavy cream
and some ice. :nod:
  • darth-vader-drunk.mp4
    535.4 KB
