I'm with Stefano here in that the problem lies with the IXTH part which is self biasing, as opposed to the JFET used in ZV9 or the MOSFET used in the original Zen.
Thanks guys!
The JFet in ZV9 is self biasing as well .And has a proper working "point" for the circuit . Look also at figure 10 " De Lite De Lux " .
Hey guys,
Just got back from work and measured the current. Its sourcing about 8A. I don't know how the fuse didn't blow. Perhaps, its a 10A one 😱
I'm stumped.
Stefano, I'm looking at that diagram and seeing how the drain voltage is set. But I'm getting about 20V at the drain any way. Hmmm... 🙁
I'm stumped.
You still think that your CCS is ok? 😉...measured the current. Its sourcing about 8A. ...
Well, maybe not. Here is the schematic. I've used the parts at hand. Components that have different value compared to fig2. in ZV9 are: the two 470uF caps, the NPN transistor is BC550B and the MOSFETS are IRFP140. I think all substitutions are ok, but let me know if they are not.
The CCS current is controlled by the source resistor on the second MOSFET - R6 in my schematic. The NPN transistor develops 0.66V across it and so, a value of 0.33R means 2A current. This is what I had set it up as. Changing the value of the R6 should give me different currents.
I drew this up in LTSpice, so if you guys have models for the three transistors, that would be great.
Thanks!
Fran. I seem to have the same problem you had, in that when I power-up I lose all the volts and the bulb does not light. I have wired a 15R resistor in parallel with the bulb, but still no joy.
My bulbs are 300w 130volts (not 240v) The bulb cold measures about 4.5ohms, so I thought that adding a 15R resistor might work.
Any ideas?
rob.
Any ideas?
rob.
I think you need more bulbs in parallel with what you have already. I used 240V halogen stick bulbs - you know the cheapy ones you can get in B&Q or wherever. I used 2 x 500W and 1 x 300W (1300W total) per channel.
Try it and see.....
Fran
Try it and see.....
Fran
I don't see any bias for the Fet. You need about +4v from
Gate to Source, often provided by a resistor from Drain
to Gate and divided by resistors from Gate to Ground.
The bottomost FET is the IXTH part and the top 2 are IRFP140. I thought just replacing the light bulb with a CCS would work and it won't need a special biasing arrangement - like used for the FET in Zen-lite. And I used the CCS from ZV9. Is there a simpler route or am I missing something obvious?
Thanks for help, Papa. Greatly appreciated, as always.
You need a method of balancing the currents of the two,
otherwise the Drain voltage will be either full + or full -.
The Lite bulb is a resistor, so it tends to self balance.
How about a resistor from the drain of M3 and a trimpot to ground, and disconnect R8 at the source end and connect it between the resistor and the trimpot.
Just like R14, P1 and R15 in the Zv9 schematic.
If the CCS draws more current than M3 then the drain voltage of M3 becomes to high, if it draws less it becomes to low.
Noising 2101 - Delite amplifer (Jfet)
We had a Diy exhibition Noising 2010... yesterday and Tony brought his JFet Delite.. sound really wonderful..
Here's a short youtube video of the Delite amplifer with the Feastrex NF5EX field Coil spks..
YouTube - Feastrex D5nf Field-Coil + Nelson Pass's Delite (JFET version) + Felipe De Rosa's Alguen Canto
Hi guys. I need some help with my De - Lite.
Can you cast an eye over my board and see if I have done anything silly. What is happening is that the volts are dropping to 0.6v (same as woodturnerFran). I have tried a 15R in series with the bulb (bulb measures 4.5ohms) but still no joy. The 50w resistor gets quite warm and the bulb is doing something as it gets mildly warm, bit you would not know it was on unless you put your hand on it.
The bulbs are 130v 300w
I seem to have done something wrong.
Puffin, it would help if you posted some better pictures. Its hard to tell, at least for me, what's going on in there.
How about some pics of the actual thing?
That is the actual thing?
No - it's a colour picture of the muddy black & white picture of the real thing.
Not sure they will help, but here's some more.
Thanks for that 🙂
I'm at the coast with a small reaction to DPT and flu shots,
and I needed a smile.
- Pass "DeLite" Amp from BAF
