Parasound 2125 2 channel power amp problem
Well, my amp still works and sounds great! I think if I order a new transistor I'll just order every one that is on that board and replace them all. Might as well replace as much as I can while the board is out. Another thing I wondered was maybe the original 4013 chip was bad and, when I replaced it whatever ruined the original, may have instantly ruined the new one as soon as I plugged it in sound possible? Thanks! 🙂
Does the standby LED light up when you toggle the switch? Normally when a chip it is solder to the board I do not worry damage it. What I do it is cut the pins flush to chip and then pull each one while heating it with the soldering iron. It is easy and the most important is that you do not damage the board trying to unsolder the old one.
I've not seen the standby LED light up since my on and off switch problem. When I removed the original 4013 chip, I cut it out as you mentioned and I have a desoldering iron with built in suction bulb that I used carefully on the soldered pins on bottom of board and pulled each cut pin from the board. When they are soldered on the bottom only, I just use my desoldering iron/suction bulb and works great but do cut them out when soldered on both sides of board. Thanks. 🙂 I've tested standby LED with diode check mode with it still in place.
I was looking at that diode on the schematic a while ago I think when I unhook the amp again I'll remove that board and test every component I can for opens or shorts by lifting legs. I know when I order the Q217 I cut out I might as well order all new transistors since they are cheap anyway to help make up for shipping costs. Thanks again! 🙂
Check by diode tester and ohmmeter Q217 collector to ground, what you get? When you unhook it of course.
Some posts mentioned to GND pin 1 of CD4013B.
NEVER ever ground output of any IC.
By mentioning voltages on text, many won't diagnose your problem as is too much time consuming.
Read my that post, and then post two diagrams with voltages written on it. This makes it easy for the helper to help you.
Gajanan Phadte
Gajanan Phadte
I didn't miss your request for those I just didn't want to tell you I didn't know how to do that on a computer. 😱 I'll see if I can learn how though as it would be much easier for those of you who have been helping me. Thanks very much! 🙂
