Paradise Builders
Updated assembly guide
Hi all, here some smallish updates to the assembly guide. Some guys have contacted me with the goal to translate it to german - I have sent the file and they will be posting it here, many thanks in advance!! (sorry don't have the time, the components have arrived and I will be busy packing...)
Hi pdul, I used a cable with 6 wires and industrial connectors:
DIN-Kabelstecker, gerade Pole: 6 SV 60 Lumberg im Conrad Online Shop | 733239
DIN-Einbaukupplung, Frontmontage Pole: 6 KFV 60 Lumberg im Conrad Online Shop | 733020
Not sure the pre-reg needs to be removed, but it sure helps with installation.....
Most important is how you route the GND inside the cabinet. I made some comments about this in the assembly guide, that worked well for me. With a preamp that is SO low noise it is important to not spoil the performance elsewhere....
Sorry, the link does not work. Here it is...
