You mean Frans Graphs whit different Jfets ?and resistor values
Where is is now? 😕
Tanks Frans
(I am sure he is going to post it again)
No I will not!
Just a quicky, is there any preferred value for 'idss' for the 2sk170 parts? The higehr the better?
Use 8mA Idss K170 for Q97 Q98 and Q99
Use 40mA Idss J310 for Q90
This way you will be safe.
Ricardo
Where is is now? 😕
Tanks Frans
Post 1772 http://www.diyaudio.com/forums/analogue-source/218625-paradise-builders-178.html#post3419918
No I will not!
But, I can post this 🙂
These are the most important/relevant messages regarding PSU and Pre-Reg.
- Mpp #4375 PSU-pre-regulator.
- Mpp #4610 V2 Schemas UPS and Amp.
- Mpp #6506 CCS fine-tuning.
- Mpp #6462 PSU with my notes.
- Mpp #6809 Do not try to feed the CVS of the CCS of the shunt with a regulated power supply.
- Mpp #7127 More about transformer selection.
- Mpp #7635 Single and dual transformer wiring (also corrected drawing) (See also #7733).
- Mpp #7733 Grounding (PSU, RIAA and Player).
- Mpp #7810 35V PSU for the CroMagnon.
- Mpp #7830 The PSU explained.
- Mpp #8386 My resistor recommendation’s.
- My Paradise #56 PSU Noise.
- Masterpiece #951 That's not a PSRR test (it's a CIR test) 🙂
- PradiseBuilders #13 Schema's and assembly guide.
- PradiseBuilders #155 Vdc input voltage minimum simulated.
- PradiseBuilders #970 PSU oscillates; posible solutions?
- PradiseBuilders #983 Compensating the PSU for oscillations.
- PradiseBuilders #1173 Fixing oscillations (up to #1182).
- PradiseBuilders #1322 Fuse 🙂.
- PradiseBuilders #1387 Updated Paradise R3 assembly guide (Also German).
- PradiseBuilders #1403 Capacitors bad vs good.
- PradiseBuilders #1593 PSU Power Transistor selection.
- PradiseBuilders #1644 PSU Output Impedance.
- PradiseBuilders #1680 PSU Power Supply Suppression Ratio(PSSR).
- PradiseBuilders #1772 NJF selection for the PSU.
- PradiseBuilders #1887 Empirical NJF Rgs determination.
- PradiseBuilders #2127 More about the PSU fets (J113's etc).
Have a look at these and their following messages.
This is a very important collection of links.... maybe you could add a link to this post to the first post in this thread so everybody could find it easily.
Ricardo
YES !!!!!This is a very important collection of links.... maybe you could add a link to this post to the first post in this thread so everybody could find it easily.
Include an index in the first post.
Ricardo
Sorry Ricardo, these are not 'my' threads. Only the thread 'owner' can amend the first post (and the site admin(s) and moderator(s) 🙂).
P.s. Edit: And the NSA 🙂
P.p.s. Edit: And the ATL guys 🙂
What kind of loading-selector switch are you guys using and would recommend...?
I have been looking at ELMA 1-Deck, 2 poles, 6 positions, which looks nice - But i would perfer to have a 2-deck, 1 poles, 12 position - but cannot find anything else than cheap hong kong ones on ebay. Is it possible to find what i'm looking for in better quality?
Check this out, Audio input selector switches
Have not seen a 12-position switch but you can always ask them...
DACT are really expensive, and uses elma parts for many of their switches - which is why i looked at ELMA.
DIP would work - but it sounds better not to have parallel, plus i already have my case-front-panel drilled for a rotary at the front - so too late for that now.
Anything between 8 - 12 position would work - i just want to squeeze in a few more loading values.
So maybe Joachim can help.... 🙂
What exactly is my duty ?
Please add a link to FdW post in your first post of this thread....
By the way - i found that Goldpoint does have switches custom made, so i could have the switch i wanted - unfortunately they wanted $117 + $40 shipping, and then vat+customs, so it would end above $200 which is way to much for me. so i'll probably just use the elma switch for $60 instead, until a cheaper alternative turns out.
You must dislike relays a lot.
In my new build (using tubes - don'T tell joachim 😀) I am using C&K driving relais (takamisawa), works well
Normally i don't mind relays, especially latching ones. But for cartridge input i would perfer a switch.
- Analogue Source
- Paradise Builders
