P3A problem
do you consider this a good pcb?
Just a thought, why don't you build the SymaSym instead?
It's a much nicer amp, no more complex to build than the P3a, and has good support and a tested and working PCB layout published. You can probably reuse your output devices, and the expensive stuff like the PSU should be interchangeable.
Thank you very much. that is a nice amp and i like the ideea 🙂. I will assamble the p3a tomorrow because i have the parts, but after that or if i have problems i will read the pages from that thread. seems a good job. Thank you again. I will also point it out to my friend.
I think i found the problem with the amp. Transistor BD250C has the following impedance B-C = 567 and B-E = 566, BUT when I measured the resistance across C-E it was in both ways 0.8ohm (the minimum that my milliampere-meter can measure).
So I think this is the fault with the amp. I will change it and power it up to see if this was the problem. First I will measure also the other transistors.
Hi.
I replaced the BD250C... but everything went on fire. Probably other components were damaged and thats why it burned.:hot: (this time both the power transistors are damaged, and also some resistors). In conclusion, there is no point trying to repair this one, maybe just recover the pcb board.
____________________________
Now I have almost all the parts for a new amp. I also added some pictures of the parts that i will use.
Power transistors Motorola MJ15003 and ON MJ15004. (They are in steel case, the epoxy around the legs is 5mm in diameter and the paint is wearing off hard - not very hard 🙂 - with acetone). Hope that they are genuine transistors.
I will use BC546A, as Rod suggested in his original scheme. Do I have to match all 4 transistors for hFE?(help)
For drivers i will use BD139/BD140. These should be also mached for hFE?(help)
The resistors are all minimum 1/2W and 10R,3k3 - are 1W and 0R33 are 5W.
About the capacitors I am not very sure what to use.
For input cap i should choose between 4,7u (the big red one) and a 4,7uF/50V Jamicon electrolytic one.
The shunt capacitor - C2 = 220p - I have 2 options: ceramic or tantalum??? (the blue one) - Are they OK??? (help)
The Zobel C7 and supply bypass C+&C- = 100n. Are the yellow capacitor OK??? And one more question> .1J100 are 100n/100V???(help)
The input coupling cap - C6? - and the miller - C4 - (=100pf) capacitors i only have ceramics (the small 101 marking caps) Can I use the green one instead??? (2A102J = 0,001uF i suppose) (help)
For the moment I am working to the layout of the board and I wait for your help regarding the components that i should use.
Thank you very much for your help.:wave2:
Pictures:
from post 20
Buy at least 25pairs to allow you to find matched pairs. test Vbe AND hFE @ the operational Ic. Select for Vbe <+-1mV and hFE <+-5%.
yes, the input transistors should be matched. You must arrange for the correct current to flow while doing the test.
R5 passes between 1.5mA and 2.5mA.
Have you contacted Bob Ellis to buy some BC546c and BC556c yet?
You will need to measure the voltage across LED1 correctly. Your diagram shows 2.5V, this cannot be right for an ordinary LED.
Let's assume 2mA at the moment then each half of the LTP passes 1mA. That is the test current that must flow to check the Vbe and the hFE. Be careful checking Vbe and monitoring the base current, the DMM resistance will change the apparent impedance/voltage at the base and distort your answer. A 10M input resistance on your meter will help reduce the error
The drivers do not have to be matched. But some builders says performance is improved if you do so. This time match for hFE at operational current.
That blue one is not Tantalum.
Tantalum is polarised and low voltage. That is a high voltage ceramic disc with a HiK dielectric, not good for audio.
that is actually what rod recommends. because with the lower voltage ceramics (50V) the operating voltage is a large percentage of the voltage rating of the cap so capacitance varies wildly. with a 2kV cap, the operating voltage is only a very small percentage of the voltage rating of the cap so capacitance should only vary by a very small amount.
search for polypropylene in values above 100pF.
For lower values only silvered mica and polystyrene are any good for audio. I have not been able to find low value PP here in the UK.
All the ceramic vary capacitance with voltage changes. The HiK version worse than the low K versions.
