I'm using 1.5 Amp quick-blow fuses in the speaker O/Ps. A bit low maybe but then again, I'm pushing only a few Watts at the moment and they haven't blown yet. I'm not concerned with the ultra purist notion of non-linearity of fuses in the O/P chain; to me the idea of no O/P transformers in a tube power amp overrides most other considerations. Anyway My Tim Mellow OTL is now singing happily day in, day out.
I agree on all points. I too have quick-blow fuses in series with the speaker outputs. The only time I've ever blown them is when running into dummy loads, testing the maximum power before clipping. (Which, by the way, really does reach the expected 25 W into 8 ohms.)
Chris
Old Romans sais "no risk, no win"I wonder sometimes about whether output capacitors would really be that beneficial in the event of a catastrophic tube failure. If the output voltage on the upper tube's cathode suddenly went to one or other of the B+ or B- rail voltages because of some failure condition, I could imagine the surge current through the speaker would be pretty massive even if there were a capacitor in series with the speaker coil. I could imagine the coil would get fried either way, with or without the series capacitor. Fuses hopefully take care of the situation anyway after a short time, but the initial surge before they can act is maybe the bigger risk.
Anyway, I just hope for the best with mine, and it's been OK so far, which is about 5 years with using the amplifier almost daily.
As to whether an output capacitor would affect the sound, since the power supply capacitors are in the audio path anyway, I wouldn't think there should be much difference to the sound either way, as long as the output capacitor is large enough.
Chris
But I stay with ot coupled otl (otl/esl)
do you use air conditioning? and what is your ambient temperature.....
I keep the temperature in the house at 18°C. At this time of year the outside air temperature averages 10°C. We do not need air-con in this part of the world. Most private homes do not have it, as the summers are never very hot, just warm.do you use air conditioning? and what is your ambient temperature.....
Yes, but only with a good fan arrangement. Without it, the chassis gets too hot to touch after 3 hours of running.thanks, at those temps, OTL run quite comfortably...
One issue with force air cooling fan that blew air through the top from beneath is that if a big capacitor is busted, the stream of hot electrolytic chemical can also sprout to a few feet high that could be dangerous to a person looking down near the amp.
The chassis temperature raised is mainly due to radiation from tube that heat up chassis, just like solid state device cooling fins are expected esp. for small chassis. If some cooling fins are mounted on tubes, they will also cut the radiation therefore reduce the chassis temperature. Look here for some more interesting cooling arrangement
that would be due to gross errors in wiring.....
i never had a scenario like that playing out when the
amp has been tested and confirmed working normally...
If you don't have fuses for the individual output tubes you are living dangerously.
They should be rated no more than 1.5amps each. If you have them installed there will be no need for a speaker protection fuse (unless you are running a lower powered speaker like a PHY driver) and no need for an output coupling cap.
Do you suggest slow-blow or quick-blow?
Hello
My version of Tim Mellow OTL.
Some mods
- Balanced inputs
- ECC808 input tubes (Valvo, Hamburg, 60`s)
- Microcontroller based HT power delay (~ 15 min.)
More pictures
https://postimg.org/gallery/15zbrq7o6/
Some mods
- Balanced inputs
More pictures
I'm like it very much!
(As Zen Mod would say, Fugly!)
Those thing definitely on my bucket list.
Regards,
Gyuri
Regards,
Gyuri
Before using any 6C33 they should be pre-conditioned for at least 3 days and nights by running the heaters with the plates, cathodes and grids tied to one side of the heater circuit. This will minimize arcing and double the life of the tubes.
Hello,
I`t clear to me why tube should be conditioned with heater voltage applied.
But why need connect plate, cathode and grid with heater?
Could you explain, please?
- Tubes / Valves
- OTL designed by Tim Mellow with 4 6C33C?
