OTA - One Transistor Amplifier
This is a Common Drain implementation, not Common Source. If it where, your're quite right the out z would be 5R. As Jorge said, out z of a CD circuit is 1/gfs. I'm not shure what it is at 2,6A, but it is more than 0,4S... :shutup:
Single ended class " A " amp is from DC look voltage divider 1:1. If bottom part of this divider have " impedance " 5 Ohms, the same must be upper side impedance. Output impedance of this divider is " bottom " side in parallel with " upper " side = 2.5 Ohm...
See the output impedance of a similar circuit...and tell me the diferences.please! 😉
http://sound.westhost.com/project83.htm
Bandwidth (-3dB) is from 4Hz to 250kHz. Rise time is 1.5 us. Output resistance 0.16 Ohm.
Here's how it looks like 😉
I used a PCB, but this amp is better do just p2p. The reason is that this is my revised SEWA (Rev.1) chassis, and it uses a pcb of this size. So now it was just to pop in this instead to have a listen 😉
