Organ amp conversion
Hello everyone, starting a new project. I picked up a pair of lowery organ amps. From 1958 holiday ls models. Going to run as mono blocks. Power tube are 6v6gt pp. But the power supply ran 20+ tubes in the organ. So was wondering if the PS. Would support tubes with higher output? Maybe el34s?
Thanks for your Input.
Here is the original schematic, main unknown is transformer current rating. But seems large for just 3 tubes plus rectifier.
The yy part of the transformer is labeled 12.6V 8A which would mean it was meant to power a whole lot of tubes like 12ax7, 12au7 or so. The xx 6.3 volts 5a is more than enough for the 6v6s and 6sn7 which come out to 1.6A. Some of the extra current rating on the xx likely ran some tubes that used a 6.3 volt heater.
Do you plan to use the output transformers or replace them?
The 340v plate voltage might be a little low to make good use of EL34s.
Parallel 6v6s look easy. You have the heater supply and plate current for it.
You may be able to run a quad of 6L6s as a guess. You would just need to run the heaters in series on the 12 volt yy.
Reactions: Jasonkilo
I guess next question is if there is a place for an extra pair of power tubes that is close to the original pair. Are there external power sockets that could be knocked out?
You may be able to get 360 volts on the plate supply if you get rid of the 120 ohm resistor in the center of the plate supply.
A quad of 6v6s may get you close to 20 watts UL. You can get a little more with 6l6s or 5881s. The power transformer should get you 25 watts if you pick the right output transformers.
Plenty of room for more tubes, and a larger OT. Also will probably look into adding a choke. I feel it would help with the B+. They have plenty of extra sockets that are used for the organ. So I'll re-use them for output tubes.
Tube rectifier is dropping about 25 volts. I guess the big question is how much power are you looking for? It would be great if we knew the power transformer current rating. I would say it was at least about to do 175MA but it could do more.
If you measure the power transformer HV primary voltage you can avoid some guessing.
It depends on what you want to use for output tubes. A pair of 6v6s will not get you past 10W UL.
You might get 20 W with a quad of 6v6s.
You might want to study the tube datasheets for 6v6, 6l6, 5881. Tung Sol 5881 datasheet has a good example for UL configuration if you look.
If you move up to 6l6s or 5881 you can tolerate more plate voltage and get more power either with a pair or quad. There is enough heater current with the transformer to support more tubes.
Another note is in the stock unit you are dropping 20v in the bias resistor from the HV CT and ground. The rectifier drops about 25 volts.
Stock amp shows 340 volts on the first cap which goes to the output transformer CT. They show 20 volts dropped in the output transformer which is typical.
With UL configuration the screen voltage is the same as the plate. You usually can have slightly higher screen voltages in UL compared to pentode as far as ratings go.
You are mostly worried about screen power dissipation in most cases. Worst case screen dissipation happens when the plate voltage swings to zero. In the case of UL with 50% taps, the screen would be at half voltage if the plate swings to zero. Worst case screen dissipation is avoided.
