• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
OPA1656: High-Performance CMOS Audio Op Amp
Can't imagine anything over 4-5" silicon on sapphire wafers, but I may be rusty since I worked in a fab (2" at the time, don't ask the cost 😀)
Sorry, I was referring to TI having a 200mm isolated process, tops. Maybe still 150mm. Pretty sure SoS is 100mm. I never did SOI, but did wafer bonding for a specialized process to create an extremely deep PIN diode structure (the undoped layer being on the order of 150um thick, so that was a case of bonding a highly doped wafer to an undoped (extremely lightly doped) wafer, and then lapping back, implanting, annealing, lapping surface.
Global Foundries has a few different SOI technologies, some with very thin Box (Buried oxide layer). They have been promoting the 22nm FD-SOI (Fully Depleted Silicon on Insulator) for quite awhile.
One of my engineering instructors once referred to Silicon On Sapphire as $O$.
Another company using SOI - pSemi - Intelligent Electronics for the Connected World
He was involved with the "gate first" SoC-on-SOI process at GF, which I think is at 12nm now. Anyways, we're a biotech company, so new challenges. 🙂
And I had forgotten to put the link to PSemi when I alluded to a "San Diego SoS company". One of their founders gave a talk at my uni a while ago, but, yes, we're talking the same company. 🙂
Yes. I think the equipment suppliers are more focused on the high volume, low voltage applications, such as 22nm FD-SOI applications.
I remember MeV implanters were used for the deep isolation wells
It is not easy to imagine a 2.5MeV ion implanter, able to deliver 100mA or more of beam current. The power supply needs to be 2.5MV, that's 2,500,000 volts, and a power of at least 500KW. And that power needs to be somehow dissipated/cooled to avoid a general meltdown. Essentially a giant 2 stage water cooled vacuum tube, with 3 stages of vacuum pumps (roughing, turbo, ion getter). Has a ECR (Electron Cyclotron Resonance) ion source. An apocalypse machine, could be used in a Mad Max movie.
P.S. You don't stay anywhere close when the machine is running, if you value your health and life. Bremsstrahlung (cyclotron radiation, in this case) is not funny to ingest.
Sorry, deleted post. Will think more about it overnight. But yes, water cooled tubes, 8' thick borated concrete walls around the cyclotron room (for neutron capture), etc. Don't know if these machines are ever used for semiconductor ion implantation.
Depends. There is a range of silicon thicknesses that make the SIMOX process impractical. It is very difficult to polish to a, say, 10um thickness without cracks and induced stacking faults in the silicon, that cannot eventually be gettered also due to the limited thickness.
I am pretty sure the BB SOI process for Difet is a version of SIMOX (wafer bonded) process. I don't think anything else was available in production at that time (other than the crazy SOS), and I vaguely remember seeing some patents about.
Enough of this, otherwise I'll have nightmares about the phosphine and arsine bottles tonight 😀.
The problem with the old bonded wafer DI process for 36V Analog is the equipment and many of the Fabs are old (replacement equipment parts can be hard to find) & have limited capacity. The Manufacturing side of the company often just raises wafer costs till the Product line drops the process use (or the product line is forced to an outside foundry). In the meantime ,the product price raises to cover the cost of manufacturing. To invest in new Fab equipment for any newer process technology requires a Product line commitment for adequate long term wafer volume with good margins.
It more practical & cost effective to use the newer high volume ICs for new designs (that are run on high volume process technologies). There are many newer Audio quality Op Amps available, that are much more cost effective than the very old BB DI products. There are newer products that are a much better value, even if one chooses not to use the excellent OPA1656, see attached
I'm using the OPA1612 in a new design, and a phenomenal piece of work that it.
Why, with so many zeros in the distortion figure don't TI quote it in ppm? 0.15ppm is much easier to understand and compare performance figures than 0.000015%
The comparison would be quoting capacitance in uF regardless of size - 4.7pF is easier to understand than 0.0000047uF
I think the MeV implanters are running lower currents than for the shallow SOI implant.
For higher voltage (> 10V) SOI, the bonded wafer approach is probably much more practical.
Another option is to grow oxide on a wafer. Then grow epitaxial silicon on top. Build the devices in the EPI.
I seem to recall that you can buy wafers that already have this work done.
Tom
