Well, as it happens I have just received an email from Pavel. Hope he does mind that I share with all of you what seems to be a recognised problem.
The firmware revision 1.34 with the Okto DAC8Pro does not work under linux. OktoResearch team received the information that I sent to them and have just confirmed that. My preliminary data showed that malfunctioning.
Pavel also says there will be a new firmware version in two/three weeks.
Good to hear there is movement on the issue.
There needs to be some company sponsored "VERSION RELEASE NOTES/KNOWN VERSION ISSUES/WORK AROUNDS/VERSION BUG FIX" list somewhere. Customers could consult it and get their questions answered a lot quicker without having to get the same questions answered numerous times.
As for the new release, the "FLASH KIT" needs to also be released.
You are right about the flashing tool, I do not envision any tech reason they will not get it done easily.
If I were them, though, I would be very worry to allow such a tool in the hands of everyone. Flashing an XMOS is a process that if goes south, can brick your unit. That would require sending the hardware home for a proper flashing. Risky business I see there
cheers
cheers
Lindamar,
Any updates on a new "Linux Friendly" flash and flash kit ?
TIA
I am afraid I do not have a solution yet. It seems to be coming though, or so I was told by OktoResearch
still waiting to use my unit
I am happy to report that I have received a pre-release version of the new 1.4 firmware revision. It seems to work well under linux 🙂 . The official over-the-USB update package will be available at the OktoResearch website soon, according to Pavel.
My system is a Linux machine running HQplayer embedded. It doubles both as a player and as a crossover, with FIR filters (65536 taps) on all channels.
So those are the good news and I wanted to share them with you
Glad to hear you are up and running. You have had a long wait.
if you are the same person who asked this question on ASR forum, I can confirm that brutefir plugin for Volumio (currently called "DSP plugin for Volumio") supports multichannel DACs, so you can have high-pass and low-pass filtering together with FIR filtering on each channel.
I will be happy to assist you how to configure what you're looking for as I was the one who helped creating this functionality within the plugin, but we never had the chance to test it.
FWIW, Stereophile did a "Not a Review" of the OKTO DAC8 PRO and it looks like there is a review of the stereo version in the works.
Okto Research dac8 PRO D/A processor | Stereophile.com
Hey Pavel,
ASR mentioned in their review
Will you release a DAC 8 Pro incl. DSP?
There will be two other versions, one with DSP and the other in stereo configuration
Hey Pavel,
FWIW, OR made a few DSP versions that used the miniDSP nanoSHARC board, but miniDSP deprecated the board in 2019 and is no longer producing it.
Legacy products
I don't know if OR is working on an alternative DSP version.
It would be great if the DAC8 PRO had a mic preamp input so that a single USB clock could be used for both input and output to make accurate FIR filters without random clock drift issues.
I have been trying the Audiolense demo program with a miniDSP USB UMIK-1 and the USB DAC8 PRO. Since both USB devices have their own clocks, there is random clock drifts causing inconsistent time measurements making it unusable for proper time alignment and phase correction calculations.
I did some research and found what you already wrote. Question is if i can order the DAC 8 Pro with RPi and nanoSharc preparation, because here in Germany dealers still have stock of nanosharcs.
/edit
Not new but used nanosharcs
/edit
/edit
If memory serves, the RPi/nanoSharc version was built around pre-production boards and cases that had different go-innies and go-outies and more interior space.
Maybe Pavel can chime in to what he has up his sleeve and if it is possible with the new production boards.
Old Pre-Production Case:
New Production Case (smaller case with extra AES3 inputs):
I placed my order today and waiting for some answers from Okto. Looks like they changed the I/O board for 4xAES/EBU and theres no room for the RPi anymore. AES/EBU is also fine for inputs, but my Apple TV only have Audio by HDMI. I can get ATV Audio from my Epson Wireless Sender via Toslink, so i need a Toslink - AES/EBU Converter.
Is this what you are looking for ?
http://www.canare.com/UploadedDocuments/110%CE%A9-75%CE%A9%20Digital%20Audio%20Impedance%20Transformers.pdf
What is the latest Windows DIYINHK driver for the DAC8 PRO ?
I have 4.59, but I see references to 4.67.
Does anyone have any details and where the latest driver can be downloaded ?
Thanks much.
Thanks much.
@Okto Research (Pavel),
Are there any updates on a Linux friendly flash kit for the DAC8 PRO ?
Thanks much.
Thanks much.
/edit
Can you please post some links where those nanosharc boards can be found
- Vendor's Bazaar
- Okto Research DAC8 PRO and DAC8 Stereo
