What are the USB IDs you see when running Volumio and what does /proc/asound/cardX/stream0 show (replace cardX with the correct value for the Dac8)?
Thank you wealas, there you go:
Code:
volumio@volumio:~$ cat /proc/asound/card5/stream0
OKTO RESEARCH DAC8PRO at usb-0000:01:00.0-1.3, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 8
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000
Data packet interval: 125 us
Interface 1
Altset 2
Format: S16_LE
Channels: 8
Interface 1
Altset 3
Format: SPECIAL DSD_U32_BE
Channels: 8
Capture:
Status: Stop
Interface 2
Altset 1
Format: S32_LE
Channels: 8
Endpoint: 2 IN (ASYNC)
Interface 2
Altset 2
Format: S16_LE
Channels: 8
Well, on the OS level it all looks good. You should be able to try something like:
speaker-test -c8 -D<name of alsa card here> -r48000
and see if anything comes out of the dac.
You can find the card name from aplay -L
more info coming
lsusb -v
lsusb -v
Code:
volumio@volumio:~$ lsusb -v
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 31
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Bus 001 Device 006: ID 20b1:2009 XMOS Ltd
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x20b1 XMOS Ltd
idProduct 0x2009
bcdDevice 1.20
iManufacturer 1
iProduct 3
iSerial 2
bNumConfigurations 2
bLength 9
bDescriptorType 2
wTotalLength 463
bNumInterfaces 5
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 3
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 8
wTotalLength 125
bmControl 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 41
bmAttributes 0x03 Internal programmable Clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 9
bLength 8
bDescriptorType 36
bDescriptorSubtype 11 (CLOCK_SELECTOR)
bUnitID 40
bNrInPins 1
baCSourceID( 0) 41
bmControls 0x03
Clock Selector Control (read/write)
iClockSelector 8
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmChannelConfig 0x00000000
bmControls 0x0000
iChannelNames 11
iTerminal 6
bLength 42
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 10
bSourceID 2
bmaControls( 0) 0x0000000f
Mute Control (read/write)
Volume Control (read/write)
bmaControls( 1) 0x0000000f
bmaControls( 2) 0x0000000f
bmaControls( 3) 0x0000000f
bmaControls( 4) 0x0000000f
bmaControls( 5) 0x0000000f
bmaControls( 6) 0x0000000f
bmaControls( 7) 0x0000000f
bmaControls( 8) 0x0000000f
iFeature 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 20
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 1
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmControls 0x0000
iChannelNames 19
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 22
bAssocTerminal 0
bSourceID 1
bCSourceID 40
bmControls 0x0000
iTerminal 7
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 4
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0320 1x 800 bytes
bInterval 1
AudioControl Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 2 Decoded PCM samples
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0190 1x 400 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bmFormats 0x80000000
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 5
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 2
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
bInterfaceProtocol 1
iInterface 10
Device Firmware Upgrade Interface Descriptor:
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Manifestation Tolerant
Upload Supported
Download Supported
wDetachTimeout 250 milliseconds
wTransferSize 64 bytes
bcdDFUVersion 1.10
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 33
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 8
bLength 9
bDescriptorType 2
wTotalLength 463
bNumInterfaces 5
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 3
bFunctionSubClass 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
iInterface 3
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 8
wTotalLength 125
bmControl 0x00
bLength 8
bDescriptorType 36
bClockID 41
bmControls 0x07
bAssocTerminal 0
iClockSource 9
bLength 8
bDescriptorType 36
bUnitID 40
bNrInPins 1
baCSourceID( 0) 41
bmControls 0x03
iClockSelector 8
bLength 17
bDescriptorType 36
bTerminalID 2
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmControls 0x0000
iChannelNames 11
iTerminal 6
bLength 42
bDescriptorType 36
bUnitID 10
bSourceID 2
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 20
bAssocTerminal 0
bSourceID 10
bCSourceID 40
bmControls 0x0000
iTerminal 0
bLength 17
bDescriptorType 36
bTerminalID 1
bAssocTerminal 0
bCSourceID 40
bNrChannels 8
bmControls 0x0000
iChannelNames 19
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 22
bAssocTerminal 0
bSourceID 1
bCSourceID 40
bmControls 0x0000
iTerminal 7
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 4
bLength 16
bDescriptorType 36
bTerminalLink 2
bmControls 0x00
bFormatType 1
bNrChannels 8
iChannelNames 11
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 5
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 2
bNumEndpoints 1
iInterface 5
bLength 16
bDescriptorType 36
bTerminalLink 22
bmControls 0x00
bFormatType 1
PCM
bNrChannels 8
iChannelNames 19
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 8
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
iInterface 10
bLength 9
bDescriptorType 33
bmAttributes 7
Will Not Detach
Upload Supported
Download Supported
bcdDFUVersion 1.10
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 8
Bus 001 Device 002: ID 2109:3431
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x2109
idProduct 0x3431
bcdDevice 4.21
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
aplay
Code:
volumio@volumio:~$ aplay -v Gottschalk.wav -D surround71:DAC8PRO,0
Playing WAVE 'Gottschalk.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
aplay: set_params:1297: Unable to install hw params:
ACCESS: RW_INTERLEAVED
FORMAT: S16_LE
SUBFORMAT: STD
SAMPLE_BITS: 16
FRAME_BITS: 32
CHANNELS: 2
RATE: 44100
PERIOD_TIME: (125011 125012)
PERIOD_SIZE: 5513
PERIOD_BYTES: 22052
PERIODS: (3 4)
BUFFER_TIME: 500000
BUFFER_SIZE: 22050
BUFFER_BYTES: 88200
TICK_TIME: 0
aplay -L
Code:
volumio@volumio:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dmix:CARD=ALSA,DEV=2
bcm2835 ALSA, bcm2835 IEC958/HDMI1
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=2
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=2
default:CARD=Headphones
bcm2835 Headphones, bcm2835 Headphones
sysdefault:CARD=Headphones
dmix:CARD=Headphones,DEV=0
dsnoop:CARD=Headphones,DEV=0
hw:CARD=Headphones,DEV=0
plughw:CARD=Headphones,DEV=0
default:CARD=DAC8PRO
DAC8PRO, USB Audio
sysdefault:CARD=DAC8PRO
DAC8PRO, USB Audio
front:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
Front speakers
surround21:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
4.0 Surround output to Front and Rear speakers
surround41:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
dsnoop:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
hw:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
plughw:CARD=DAC8PRO,DEV=0
DAC8PRO, USB Audio
dmesg -> the last two messages appear after trying to play actually something in Volumio, which is very similar to the same type of error I get with HQPlayer embedded (bootable) and also in Audiolinux
Code:
[46144.518557] usb 1-1.3: New USB device found, idVendor=20b1, idProduct=2009, bcdDevice= 1.20
[46144.518564] usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[46144.518570] usb 1-1.3: Product: DAC8PRO
[46144.518575] usb 1-1.3: Manufacturer: OKTO RESEARCH
[46144.518579] usb 1-1.3: SerialNumber: 000060
[46144.616850] usb 1-1.3: 1:3 : unsupported format bits 0x100000000
[46144.673320] input: OKTO RESEARCH DAC8PRO as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.4/0003:20B1:2009.0002/input/input1
[46144.738037] hid-generic 0003:20B1:2009.0002: input,hidraw0: USB HID v1.10 Device [OKTO RESEARCH DAC8PRO] on usb-0000:01:00.0-1.3/input4
[46153.506647] usb 1-1.3: USB disconnect, device number 4
[46186.038794] usb 1-1.3: new high-speed USB device number 5 using xhci_hcd
[46186.169493] usb 1-1.3: New USB device found, idVendor=20b1, idProduct=2009, bcdDevice= 1.20
[46186.169500] usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[46186.169505] usb 1-1.3: Product: DAC8PRO
[46186.169511] usb 1-1.3: Manufacturer: OKTO RESEARCH
[46186.169516] usb 1-1.3: SerialNumber: 000060
[46186.284972] usb 1-1.3: 1:3 : unsupported format bits 0x100000000
[46186.341272] input: OKTO RESEARCH DAC8PRO as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.4/0003:20B1:2009.0003/input/input2
[46186.408956] hid-generic 0003:20B1:2009.0003: input,hidraw0: USB HID v1.10 Device [OKTO RESEARCH DAC8PRO] on usb-0000:01:00.0-1.3/input4
[48182.283416] usb 1-1.3: 1:1: usb_set_interface failed (-110)
[48182.959167] usb 1-1.3: 1:1: usb_set_interface failed (-71)
I believe there is a bug in my firmware. Mine is version 1.34 and serial number #60
The is no sound no matter how I use aplay. I keep receiving those "usb_set_interface failed" that you can see in dmesg
Any hint would be greatly appreciated !
Did you try speaker-test? Also try speaker-test with sudo.
Also try both the 7.1 and hw:CARD=DAC8PRO,DEV=0 cards with speaker test.
there you go
Code:
volumio@volumio:~$ sudo speaker-test -c2 -D surround71:DAC8PRO,0
speaker-test 1.0.28
Playback device is surround71:DAC8PRO,0
Stream parameters are 48000Hz, S16_LE, 2 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 12 to 65536
Period size range from 6 to 32768
Using max buffer size 65536
Periods = 4
Unable to set hw params for playback: Input/output error
Setting of hwparams failed: Input/output error
volumio@volumio:~$ sudo speaker-test -c8 -D surround71:DAC8PRO,0
speaker-test 1.0.28
Stream parameters are 48000Hz, S16_LE, 8 channels
Periods = 4
I tried there both with 2 and 8 channels
Ok, next question, did you setup the dac8pro to be in pure USB mode? I think any other mode requires AES input in order to use the input clock.
I have tried also the other card you mentioned, same result though:
Code:
volumio@volumio:~$ sudo speaker-test -c 8 -D hw:DAC8PRO
speaker-test 1.0.28
Playback device is hw:DAC8PRO
Periods = 4
volumio@volumio:~$
I believe pure USB is the default, nevertheless ... it is set as pure USB, checked !
It does look like there is some bug in the kernel that affects some usb devices: 203419 – Logitech Group USB audio stopped working in 5.1-rc6 maybe try Arch linux with a 4.19 kernel or older. Dietpi I think is still on 4.19 as well.
I have exchanged a few messages over audiosciencereview with another owner and he has it working with linux. It seems he has an older xmos firmware than I do, so that might be it.
My firmware's revision is 1.34, just in case there is another use with the same one
Has anybody heard recently from Pavel from OktoResearch ?
I have tried to contact him by email several times to no avail
ASR has 2 OKTO threads. One for the DAC8 PRO and one for the Stereo. You might want to post your question to both threads over there.
Pavel should be more responsive to product support questions (or publish a more detailed configuration manual online including revision numbers).
okto-dac8-stereo-dac-review.14705/page-32
Thank you for the suggestion @emailtim
Pavel knows about the situation with my unit, we communicated by email until he stopped answering my messages. It is and awkward situation.
There must be more customers with the same configuration and firmware revision that who have suffered the same problem I do. Either that or my unit is defective. In any case, I do not find confort in bombarding everywhere. It just takes too much emotional stress. I guess posting in "Review and Measurements of Okto DAC8 8Ch DAC .." should be enough
thank you anyways
thank you anyways
- Vendor's Bazaar
- Okto Research DAC8 PRO and DAC8 Stereo
