I suppose the noise was from the dirty ground on the rectifier side mixing with the clean ground at the psu output?
You are right. Not good to have unsmoothed rectifier outputs mixed with clean GND (after CLC) and to keep the wires from / to the rectifiers short. The stupid wiring caused nasty current flows also I guess.
@1543 Looking at your psu numbering, are you using 144 capacitors?
Instead of 8 big capacitors I have used many many many small (ø18mm) caps. This allowed me to put 2 big DC chokes, transformer and power supply in a only 300 mm deep chassis. But I must admit after assembling the M2 the supply looked a bit oversized, but it will not harm.😀
@JohnnyCanuck,
my midclass dmm says 0,0mV AC arrive at the amp-pcbs
good enough for me
even the 1mV AC at output doesn't do anything to my ears
best amp i have ever build
not yet mentioning the sound...!!!
cheers
A.
good enough for me
cheers
A.
@Attila I,
Thanks for measuring - that is an excellent result.
With luck perhaps I can do as well.
-K-
-K-
Sniff around for the M2Clone PCB sold by member "Tea-Bag" and read that thread. If I'm recalling correctly, several people built an M2 without mu-metal shielding, and loved the way the amp sounded. Several other people did make their own mu-metal shield, and they also loved the way the amp sounded. Search this thread, and that thread, for photos. I'll bet you find more than one picture of a homemade mu-metal shield on an M2 amplifier board.
I built a M2 used Teabag's boards, the Edcor trannies, the standard diyaudio store chassis, and the standard power supply using the store boards. I followed instructions and did NOT have to shield the transformers. I love this amp and it's been my main amp in my setup for over a year now. Quiet as a mouse on my >100dB horns. I have parts to build a second M2.
In fact, while on this topic, I will say that I preferred this amp to an F6 I also built and a Pass built J2.
Jim
Thanks for the pics, 1543.
I like that you mounted the rectifiers to the faceplate. Good idea. 😀
Nice Build! Is that a Toroidy tranny? How many VA is it?As already threatened here are some pics of my M2 build
First rate.
Very nice 1543, congratulations on your beautiful build!
Many thanks for your kind feedback.
Yes, the transformer is a Toroidy TTSAS0400 400VA 2x18V. They are of very good quality, highly recommended.
The mounting of rectifiers to faceplate helps a lot when space on baseplate is limited. Also access is much easier when mounting the recifiers on the faceplate.
I have shielded the edcors with Teko 3710.16 enclosures. It is easy to make them fit to teabags M2 clone boards with solder tails which can be screwed to the board.
Wow thats impressive! Some nice details there, I also like the rectifiers mounted on the faceplate. What l bracket did you use for the transformer?
Many thanks for your kind feedback.![]()
Yes I really like their transformers. I used a 2x20, 300VA in a recent build but didn’t realize I’d have to mount it vertically to fit the chassis. I had a friend weld L brackets to the mounting plate so was curious how much extra space the 400VA would take for future builds.
1543, nicely done!
That pretty transformer shield could start a fad! So... 117,500uF + 220,000uF PER RAIL in psu filter capacitance, is that right? It sure looks cool. May I ask what inductance you're using in there?
Hi you need shield with the TTSAS ? or just for sleep better 😛
Just finished my second M2 build. This time with higher class current using two pairs of output mosfets. Up power transformer to 1KVA and power supply capacitance to 176,000uF / channel. Overall saw an improvement in low end and immersive sound stage.
Who is the manufacturer of the yellow colored 600:20K transformers, in photo 4 of post #2697? Does their sonic character duplicate that of the Edcor 600:15K transformers in the original M2?
Fugly! , twice!
- Official M2 schematic
