OB "omni" experiment
Little progress- yes I know I'm not as fast as some other OB builders😀
Fired up the router yesterday
But, this is open baffle - will there so much sound pressure?
if it moves more than it should you will notice it 😉
I'm quite sure a single woofer would not cause any real big problem ... but with 4 woofers cramped into a very small space might be different than just a single woofer
btw, not sure I would call it open baffle, but more like folded, slotted, or open back, or something
First try with the 10 mm thick sound absorbing felt. This will be used inside and outside and will be covered with a thin 2 mm layer of black felt.
WHERE!!! did you get that gray felt?!! 😱
I have to import mine for a kings ransom from Sweden. I've been looking for years for a suitably cheap outlet for the stuff in Denmark (it really should cost next to nothing as it is a waste product).
It is the only other obtainable alternative to mineral wool in EU but seemingly impossible to get hold of unless you are a car manufacturer or furniture factory.
