Hi pcaddict,
Good Hunting!
Now you are really going at it.
The page magnifyier should be on the light source side and the thicker fresnel towards the projection optics side
But you have to judge it for yourself, that which of your two lenses is better for the image quality and take that decision.
the LCD has to be closely sandwiched between the two fresnels with about a 1cm gap on both sides.
Optics is a crazy science all lenses react differently to each other. The trick that I used is that keep your LCD aside as it is the most expensive and delicate part of the projector, one wrong tug at the FFC cable and your LCD is history.
Make a dummy screen of the same dimentions, with a cardboard sheet ,and slip into it a ohp sheet with some markings on it.
Use this to play around with your light source and mark all dimentions in a cardboard mock-up box to control light scatter. Once you get an image of the required quality and size, then go in for the final box and lcd placement.
Best of luck.
And yes smooth sides of fresnel are towards the lcd on both sides
Good Hunting!
Best of luck.
Hi Budhi,
can u give me the specifications of the fresnel u used?
Sorry to trouble man..
Thanks,
Cool
Thanks,
Cool
mrcoolbuddy said:Hi Maks,
Im also from Bangalore...
Can u tell amy place where i can get Mettal halide lamps and the ballast for it?
Thanks,
Cool
Hey mrcoolbuddy.... sorry for the delayed response. I had gone to my hometown, Mumbai, for Diwali celebrations.
Well, I bought the MH lamp with fittings from a shop named Prestige Lites on the CMH road. It cost me 1900 re. with ballast and fittings.
mrcoolbuddy said:Hi All,
Can you please give me the specifications for the fresnel lens, the condensor lens and the final Focusing Lens?
Wats the diameter, width, height, focal length any other specifications etc....
Does anybody where in bangalore we get all these cheaply?
Thanks,
Cool
I searched the whole of Bangalore upside down.... but couldn't find any dealers for lenses... One friend of mine is helping me to get these from a source he knows.
Thanks Maks
HI Maks,
Thanks a lot buddy....
now that i can also buy the lamp from there..
Can u just give me the specification of the mettal hallide lamp n ballast u purchased so that i can buy the same?
Once u get the info on where to buy fresnel lens pls do tel me too.
thanks again.
Cool
HI Maks,
thanks again.
Cool
Re: Thanks Maks
Hey... I do not remember the model no. for the lamp, but it's a 150W MH lamp, OSRAM make. Actually, U need not bother abt all this... jst go to the shop ans ask for it... the owner is Dinesh Kumar.. he'll help you out.. btw, which part of Blr r U put up in?
mrcoolbuddy said:HI Maks,
thanks again.
Cool
Thanks again Maks...
Im stayg near BTM Layout 1st phase.....which part r u from?
I did ask some places for fresnel lens...But of no use...
If u get info pls do tell.
Cool
Cool
Hi Fellow Diyers,
Iam from India too but currently living in srilanka. Were do you guys get your lens and lcd. How about sharing the information in this thread so what other like me will be able to get the same...
Item,Shop Name, City and Price
Well we can get everything from LL but the shipping is the killer.
I bought the LCD screen from a local market here... the set of Lenses is being arranged by my friend from Lensel Optics, Pune. Look out for their website.
Thanks Max
Can u tell me from which local market u bought the LCD..n for how much?
can u give me the exact location since im also from bangalore....
Cool
Cool
mrcoolbuddy said:Thanks Max
Cool
Hey... I bought the LCD from Mumbai as I had gone there for Diwali. It's a 7" screen with 16:9 aspect ratio, and built in tuner. It came for 3750/-. I dunno where in B'lore can we get the same type of screen, but you can visit SP road and hunt for it. I am planning to go there this saturday, so let me know if you wanna accompany..!! 🙂
I have been following this thread for a while, and I am interested in the DIY projector too.
mrcoolbuddy:
For LCD panels (for ones used in car), try JC road also - lot of automobile accessories and spares.
Alternate can be National Market (close to Tribuvan theatre, near Majestic).
And yes, please post your findings.
Best of Luck !
mrcoolbuddy:
Best of Luck !
I stripped the LCD this weekend... and also got the FFC cables from the local market.... one for the control boards, and other for the LCD. It cost me Rs. 70/- and Rs. 200/- respectively. But these are kinda plain FFCs and not extension cables. While I could manage to link both the LCD control boards with one of the FFCs, just wondering how can I extend the LCD panel thru the control board with this plain FFc. Any inputs..???
Maks.
Maks.
Maks this is how i managed to make an extension for my LCD side cable using the simple FFC cable.
I use only 16pins the rest are blank 🙂
Could not mail ur Fresnel and triplet today ... the Courier guys did not accept it shall mail it tommorow
Cheers
Mastero
Cheers
Mastero
Even I was planning to do it in a similar fashion, but could not find this small connector here.... will go for hunt this weekend again. Thanx anyways....
Great job Budhi. I am new to this forum. I have decided to make my own projector. My main concern is what to buy first, the LCD panel or projection triplet lense (for me it is like what came first the hen or the egg). Please help me regarding this. Thanks.
if I were you I would first off buy the lcd panel so you know the correct size of lenses to buy. Also, if the lcd cannot be taken apart then you won't have lenses lying around with no use.
Just my thought..
Just my thought..
I agree with Rob.
I would first purchase the LCD and see it if can take it apart and see if I am convinced it can still be used for the projector. Then I would work around the design and procure all other parts.
Else I would put the LCD back and put it to any other use.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- NEW projector from INDIA
