The neodymium versions will be more pricey and they will have a smaller back chamber, so may require more mod work?
Interesting double half roll surround on that "370"...
What were the mods to the 370??
Hi Bear,
just the 0.1mm thick spacer with the wider inner diameter.
That's it.
Klaus
You have you units of measure confused again, 2.05 mm??
We need to cut him a slack. It's really hot in Sweden these days.
Dammit. 20.5mm.
I am melting, yes. Arctic creatures should not have to endure 27 degrees C, three days a year!
News on possible spacer ring material:
I found 0.3mm copper sheet with adhesive on one side on ebay. This may not be 0.1mm but it was very cheap and soft and easy to work with. Draw a line with a pencil and cut with a razor. 3pcs 10x10cm 0 3mm 29ga Jewelry Making Pure Copper Plate Sheet Craft Findings | eBay
I will use it under the membrane surround, on the magnet side. Just one ring, because of the 0.3mm thickness. Then my design will only differ with 0.1mm from Dietmars trials.
I looked for a sheet without adhesive but it might make working with it even easier. The adhesive should go away with a little nail polish removal if I could be arsed.
Mica might be too soft, I like the idea of copper better, and that particular sheet of mica is a couple of millimeters to small. The voice coil of the K55 is 50.4mm.
The thickness of mica seem to vary between 0.04-0.1 mm, according the ad. That's why i prefer copper.
https://www.aemetal.com.au/Webstore/p-126-copper-shim-01mm-50cm-x-60cm-pack.aspx
This is local for me, I will purchase some when I get my drivers ordered.
Your local copper supplier should have something similar. If not I can send you some.
Back to my thought about wavelengths and if the sound quality is affected much by the last part of the horn.
If not, and if a square horn mouth is esthetically acceptable, it would make manufacturing of the horn a lot easier if one began with a high tolerance round horn throat, and then closer to the mouth, make it square, like an old edgar horn for cone drivers. I just want to avoid big lathes and nasty glass fiber with an everlasting chemical stench. Speakers should be made in wood.
There are aluminium foil pans used for BBQing which are quite thick, you may get some weird looks walking into the shop with vernier callipers.
I take BBQ-ing very seriously!
Not sure taking speakers this seriously is any healthier.
You got a missus?Yes, that could work. The challenge will be to convince the missus to part with her precious aluminum pie-forms.
She deserves a big hug for letting you fool with Audio on this dedicated level.
I can't complain either. I just wish we could move out of the city into the
wilderness, that would be great for this hobby.
I can imagine that Bear lives far away from any civilization.
- New ideas for K-55 and PD-5V compression drivers
