New Hifisonix KX2-Amplifier
Olopollo,
To run the kx-Amplifier in class AB, just leave switch J8 OPEN. Then you have R8 = 4.7k and R18 = 33k. This should give you a reading of ~200mV across [R12 + R13] which will give an output bias current of 300mA +-50mA. This will give a total power dissipation of around 30W per channel. If that is still too high for your heatsink, remove R18 altogether.
VERY IMPORTANT: YOU MUST CHANGE R5 AND R4 TO 1K!
It looks like Jim's Audio is no longer trading on eBay. If this is indeed the case, I will supply kx2-Amplifier boards from the Hifisonix shop. I'll update later in the week.
The original nx-Amplifier will soon be replaced by an upgraded and better-performing nx2-Amplifier, so I don't propose putting the old nx-amplifier PCBs in the Hifisonix shop.
Reactions: poseidonsvoice
Olopollo,
I am very grateful to you
Reactions: Bonsai
Good afternoon all! Jim's Audio does not send kx2 PCB's to Ukraine... for me there is a large problem. I can not get kx2 PCB's in Ukraine. Large request to share the gerber file of PCB for kx2. I will be very thankful for a help. Andriy.
He has answered correctly in the Conversation. Well, almost correctly 😉 I want him to start one with me.
Here is his reply in the Conversation/
