The midrange is our reference for loudness and how loud bass and treble should be. (That's a very very short paraphrase of how it works.) When you reduce mid frequencies, you will turn up the amplifier to restore that midrange to the desired loudness. So regardless you end up with the driver working as hard as before in the midrange and working harder in the bass.
That said, there are limits to the gain and dynamic range of DSP and its DAC outputs, so you likely end up changing overall gain of your designed filtering when you use mainly boosts.
So, if you don't boost above the max spl of the driver at that frequency you should be ok?
I'd be a bit careful about going that far as you'll have no headroom left for dynamic peaks.
Most easy linearization is done with Behringer deq2496 and ecm8000 microfone. Can get it as a bundle.
There is a good working self eq. Do it in 20cm distance of the driver on axis or slightly off axis.
It's a mighty tool
It's a mighty tool
IMHO opinion, the easiest EQ is Audyssey MultiEQ as found in AV receivers. It is cheap (it's included in an amp you would already get) and fully automated. Hard to have influ3nce on what it does, although you can get additional software to gain more control. I am very satisfied with what it does to any of my loudspeakers.
Exactly. It requires you to supply the desired loudspeakers and optimises performance for that setup. It doesn't facilitate NOR NEED very involved filtering. Although you could do it with the app, I am sure.
But I can tell you from experience that full range drivers with response anomalies are easily and reliably adjusted by Audyssey with excellent effect. A capable bass enclosure with a straight/unfiltered amplifier works very well too. I had a BIB with a 12 inch driver as a subwoofer. Performance was not supersmooth by itself. The transition between sub and satellites with Ciare CH250 in sealed boxes was very good. I was super sceptical about auto EQ for treble and midrange, but Audyssey apparently knows its **** and achieves an excellent result.
I have had and have several options to do manual DSP, both software and hardware solutions. I can definitely improve on midrange detail compared to Audyssey's effort, but it's a lot more involved.
I have finished building the speakers now. volume is 160L and I went with a nicely large port of 19cm diameter. I made it out of a larger waste-waste-pipe that I opened to a nice port with a heatgun, a metal bowl, pliers and a lot of swear words.
The speakers are about 110cm tall, 40cm wide and 50cm deep with 2 holey braces evenly spaced, so the speaker has 3 "compartments" inside. I filled each compartment with IKEA polyfill (IKEA sells "inner"-pillows without a nice cover, just the insides at 3€ per pillow (50cm x 50cm), for anyone wondering.
Same material as hifi-stuff at just a fraction of its cost. Also, I glued damping felt on the inside walls.
Sounds very good so far. and no sub needed for my taste.
The bass drums come out nicely in this song.
FYI/FWIW, etc., evenly spaced bracing just increases stiffness hot spots whereas spacing them at odd harmonics like locating drivers, vents averages them out, ergo less added damping required.
The kick drum opening is pretty "taut" -
Try "this" tribute to Lemmy by Steve Clarke
Nice recording! Saved as a reference. Thanks! Too powerful/dynamic for the laptop to turn up past ~1/8th max volume.
I've used his CD for more than a decade for evaluation (and enjoyment) - It consists of two long solo flights.
here's a UK copy at a reason enough price
https://www.ebay.com/itm/3740590429...QsEoi+2NNbjjGxhFcBaq7moA==|tkp:Bk9SR-LSmL2KYw
~$4.50 shipping to the US. (Ebay listing above) - sometimes it will pop up a bit cheaper -but not often.
Dan Weiss's Tintal CD is intense as he utters each pattern of the raga then plays it on a "western drumkit" - the traditional pumped reed harmonium keyboard drone part is done with a Stratocaster guitar. The sheer density of flurries of drum notes makes it tough to play for small loudspeakers and imagine would destroy some FR drivers if any level.
There's a copy of Tintal CD at Ebay US.
This sounds poor on the harmonium - clipped somewhere
Hmm. I have been listening yesterday and today to the Fane-speakers.
My frame of reference are BIBs with the W8 2145s and double mouth-horns with Fostex 206NVs.
I quite like the direct punch of the Fane speakers. The sound is a bit boomy, but that's what I asked for, hehe. However:
I am used to the BIBs rich and full "sound of wall". Even listening to rock and metal music, the BIBs develop a rich sound that envelops you. The sound has a large "body" to it. At the same time, the sound is never lingering, excessive or exuberant or "too much".
With the Fane speakers, I miss the precision and predictability of the BIBs.
The Fanes are somewhat as dynamic as the double mouth/Kirishima horns. But they're less precise with their sound.
Overall: Very interesting sound, and god, do I love the big bass reflex vents with 19cm diameter. The Fane's are somewhat similar to the BIBs in their punchy presence, but less precise.
I like that they are smaller than the BIBs (ha, go figure) and are less intrusive to the room.
However when it comes to the speakers, I still prefer the BIBs so far.
Thanks for sharing your experience. Maybe you gotta make a BIB with the Fane ? 🙂
By the way, it would be nice to see some pictures...
Yes, that was my initial thought. However with the Fanes dimensions, a BIB would turn out super wide and super deep. Like 60cm wide and 90cm deep at 2m high. Ha.Maybe you gotta make a BIB with the Fane ? 🙂
The BIBs with the TangBands are already 2,1m tall, 40cm wide and 55cm deep, that's big enough. Pictures will come next weekend. Although I'm all about practicality, so it's really just 2 big MDF-boxes with an orange sewer pipe opened up at the bottom as a bass reflex port. But hey, it works. 😀
Well look at it this way. Mount the driver on its side and it would only be 60 cm deep. And golden ratio is beautiful and what's the golden ratio width and depth assuming a 2m height? 😉Yes, that was my initial thought. However with the Fanes dimensions, a BIB would turn out super wide and super deep. Like 60cm wide and 90cm deep at 2m high. Ha.
I understand what you mean, but then again, 90cm wide wouldn't be feasable in my living room. Also, the WAF is unmanageable with 90cm wide speakers, ha 😀Well look at it this way. Mount the driver on its side and it would only be 60 cm deep. And golden ratio is beautiful and what's the golden ratio width and depth assuming a 2m height? 😉
Well, here are the speakers with and without the grille. I like to use small magnets to keep it in place.
- Full Range
- New 12" Full-Range: Fane 12-250TC
