Nelson Pass M2
Here is a version of Mr. Pass M2 amp with 2SK /2SJ fets.
resistors and some caps are smd 1210 .
if anyone wants i can share eagle files / gerbers.
thought #1: Are the 6.35mm FastOn blade connectors at top (image 1 below), spaced far enough apart? Builders probably want enough blade-to-blade distance so they are able to use insulated female connectors (images 2 and 3) on the ends of the wires.
thought #2: Might want to investigate Blasphemous Heresy . Many DIY builders of M2 have found it indispensable.
_
I think 2 is related to 47k R6 to lower it to e.g. 37k in order to be sure to be able to offset the amp to 0V DC.....? .....I used that trick myself.....up front....did not try first with 47k....but went straight to the lower value..... 🙂
MEPER is right, that R6 was lowered to 37k and the trimmer increased from 5k to 20k. This allows more resistance possibilities to compensate for negative offset, which apparently can be seen with the stock R6/R7 at 47k and trimmer of 5k.
It is blasphemy though - so maybe best to leave the artwork original to Nelson and include a note in the BOM or in this thread, if someone can't stand a negative offset?
Great looking board by the way - always amazed how small these PCBs can get, with SMD parts.
Gerbers- M2
Thanks everyone.. here is the 'art work' and gerbers. Regarding R6/P1, builders can choose what to use.
Took my own time to make it all "curvy"
All the best for your build..
regards
prasi
  • GERBERS-NELSON PASS M2-REV1 - rec_2021-04-11.zip
Very nice! I’m really liking a mix of THT and SMD (on bottom). Was there a note about potential UMS alignments in one of your screenshots?
*edit* can you describe what you meant by ‘can be 120mm away to use UMS’?
