Hello Dario
I built the amplifier starting about 2 months .I used your BOM even if some components are not at all the ones you've recommended as a final choice. I reserve further action with the necessary calm. Attached present my creation done by hand, piece by piece. I wanted to make a rigid and lightweight aluminum structure divided into two parts: the one where they lodge the splendid PCB and the other with separate transformers in another case.
these two, the features are then hosted in a yet to be built that will welcome them to implement an inertial confinement through the elastic suspension.
After the wiring I tried to turn on the amp: the LEDs are turned on and there was the click of the relay. I measured the DC offset and I found a channel on the 0.5 mA and 0.7 mA the other. More forward I will do the listening test
http://i60.tinypic.com/1z3wfol.jpg
Why have you insulated the smoothing capacitors? (the layer of air between the plastic casing and the added aluminium or metal sheet) !
Why have you turned the heatsinks on their sides and then enclosed them so they can't cool effectively?
Why have you attached the chipamps to a side fin instead of to the heatsink backplate?
Joined 2009
Hello Dario
I built the amplifier starting about 2 months ....
Good for you !
How does it sound ? This is a very interesting design and I've not heard it myself.
I assume you will have some air flow over the black heatsink but you will get some additional heatsinking from the Al frame that everything is bolted to - you could put some heatsink compound (grease) between the black heatsink and the chasis to help further.
I coated capacitors (all) with a lead foil to experience an effective fight against vibration. The last measure more 'Why have you insulated the smoothing capacitors? (the layer of air between the plastic casing and the added aluminium or metal sheet) !
important will be elastically suspend these chassis to get an inertial confinement of the structure. This part is yet to be realized.
I need time for this.
for the layout of the heatsinks I loosely based on the solution
proposed by Mauro Penasa in My Evolution Ref. (http://www.webalice.it/mauro.penasa/Evolution/Assemblaggio_Evolution.pdf)
The heat dissipation participates entire undercarriage that is aluminum together with the heat sinks.
Useful advice that will certainly put 'in place.I assume you will have some air flow over the black heatsink but you will get some additional heatsinking from the Al frame that everything is bolted to - you could put some heatsink compound (grease) between the black heatsink and the chasis to help further.
This suggestion had given the same Mauro Penasa on Evolution Amplifier (see the link above)
Hi Sontero,
it's a really original and interesting build. 🙂
Interesting, did you ever made an A/B comparison and if so what difference can be heard (if any) ?
+1
Hi Sontero,
many thanks Dario
will be very easy to remove the shield of lead and check and will give precise statements. This is an experience that I think for a long time and this is a good opportunity. But the experiment more 'interesting will be the structural elastic suspension.Interesting, did you ever made an A/B comparison and if so what difference can be heard (if any) ?
This experience then you will also transfer to my DAC that will receive the same change with the same structure.
I see that you have improved on Mauro's cooling by using the Chassis baseplate.....................
Mauro's example built is atrocious use of a heatsink.
What vibration are you trying to stop?
Also, agree the heatsink area transfering heat to the rest of the sink and chassis is very narrow, most probably ineffective. Would be way better if you flip the sink bottom up and bolt the chip down to it, even though the fins would run horizontally.
I think your judgment is too harsh. I believe that the function of heat dissipation to be effective, however, in the Evolution of Mauro Penasa.I see that you have improved on Mauro's cooling by using the Chassis baseplate.
Friends, listening test is in progress....one word : simply Fantastic, very fantastic amplifier.
Dario you are GREAT 😀
My reference for over 10 years is an OTL Circlotron homebuilt that has never been surpassed by any other amplifier.
The MyRef Fremen Edition is the same level, I have no doubt.
I also built the "MyRef A version of Penasa" .... great amp ... but the Fremen is absolutely superior in everything.
The sound of myref is very good . Currently powered by a preamplifier BA3 ( Class A Pass ) expresses a correct sound , open midrange with good stereo imaging .
It is worth building it.
I can not make a direct comparison with F5 Pass because I can not use the same speakers.
I can not make a direct comparison with F5 Pass because I can not use the same speakers.![]()
just wondering the grounding of my ref is signal ground or power ground
If you're referring to LM3886 ground pin:
The original My_Ref (Rev. A, B, C) and the My_Evo use signal ground.
My_Evo Rev. A and My_Ref Fremen Edition use power ground.
Finally
I can't believe it has been almost 3.5 years the finished boards have been sitting on my workbench. I am finally listening to the finished product. I am very pleased so far and they seem to improve with each song. I ordered from the diyaudio store the Dissipante 3U chassis and can highly recommend it. Both channels are dead quiet. I will do some more critical listening in the near future and get back with my final opinion but I am sure it will fare well. I will be comparing it to Pete Millet's engineers amp (tubes), a heavily modified Michaelson & Austin TVA-1 (more tubes and my reference) and I may pull out my old gain clone just for the fun of it. Finally finished.🙂
Re: Finally
Congratulation!
I have several projects like that, so I understand how time can get away. At least you had some other cool stuff to listen to in the meantime.
Jac
Congratulation!
Jac
Finally finished.🙂
Pics please 😉
Posting pics
I have no clue how to post pics. The "insert image" icon asks for an http address so I am assuming that I upload photos somewhere and then enter the link but where do I upload them?
As long as they are not too large, you can just attach pictures. See "Attach Files" below when making a reply.
- Chip Amps
- My_Ref Fremen Edition RC - Build thread
