the dual transistor multiplier allows temperature compensation of the output stage bias currents by monitoring both the pre-driver temperature and the output temperature.
The effect of driver Vbe changes with temperature do not need compensation.
GEirin,
I said "greater".Diamond buffer output has great thermal instability?
GEirin,
1.2V reference would be better. Would you tell us confidentially who's the mastermind behind the arrangement around T5 and what prevents you from using active current sources?
"Some one had blundered:
Theirs not to make reply,
Theirs not to reason why,
Theirs but to do and die."
-Tennyson
-Tennyson
Joined 2009
Would you be interested to learn how to run simulations ?
If you have a PC type computer you can download for free a very good simulation tool that is quite popular by people on this forum - meaning that you can get some help using it.
go here: Linear Technology - LTspice IV Downloads and Updates
Hello AndrewT.
Thanks for you reply.
Why 2SA1360 is not suitable as driver?
• Complementary to 2SC3423
• Small collector output capacitance: Cob = 2.5 pF (typ.)
• High transition frequency: fT = 200 MHz (typ.)
GEirin
GEirin
- My update lin topology
