My Take on X-BOSOZ
Fixed PS
NPN and PNP just as it should be. 🙂
Thanks for the correction Steenoe. Don't know how I missed that. 🙂
Cheers!
Russ
EDIT: I also added two more aeners for the negative rail so this PS can be more universal. 🙂 Thanks Tony.
steenoe said:
2+2 🙂
Steen.
Ps. Slight correction😉 Mosfet's are N-channel and P-channel😀
Thanks Steenoe,
This is my first FET design, so I will need to catch up on the terminology.
Look like Most people will want 2x2 so I will probably make that the standard package. The good thing is even if you decide not to use the second PS you will have a goood one to use with another project. 🙂
Cheers!
Russ
