My Take on X-BOSOZ
Question about the FETs.
It seems the IRF610/IRF9610 are pretty much obsolete. So I was looking for good alternatives.
Any suggestions?
I was thinking
IRF620 with IRF9620 for the PS and IRF614s for the preamp.
That way the P and N channel FETs match for the PS and you get a better spec'd part for the pramp. The IRF614 seems like a better part than the IRF610, lower internal capacitance especially.
Any thoughts?
Russ
Nelson has said that IRF510 is as good as 610 if not better, at lest if my memory is still with me. I have 510's for my bosoz.
www.elfa.se has IRF610/510/9610/9510
price for IRF610 is about $1 for quantity under 50 and $0.5 for q. under 250 and $0.4 above.
For IRF9610 the same is about $2.2/$1.1/$0.9
/Tobias
BobEllis said:
IR lists the IRF610 and IRF9610 as active parts - percieved shortages may be due to the upcoming lead free requirement. the IR part number for the lead free 610 is IRF610PBF. Same for the 9610
http://ec.irf.com/v6/en/US/adirect/ir?cmd=catProductDetailFrame&productID=IRF610
http://ec.irf.com/v6/en/US/adirect/ir?cmd=catProductDetailFrame&productID=IRF9610
Right I know you can get them, but many of the sources say it is being phased out, and is not suitable for new designs.
Also It looks like some parts just have better specs. Espcially in terms of capacitance.
Hi folks,
I've been following this from the beginning and am quite interested.
I may be able to help out on a parts GP to a certain extent. The question of IRF610 availability has come up and I 'may' have a source for new surplus in a quantity that 'may' be able to fulfill almost any size gp. I think they are 'IR' but possibly Fairchild IRF610b. I will probably be able to get them for less than 20 cents per ..usd.
Brian Donegan,
I see you are in MA. Well, me too. I could hand deliver to you in the event that it could all work out. If you have any interest I would like to see if I can get them and help out. Drop me an email if interested and I will do further research.
Regards,
Marc
forum or:
mpmarino at gmail dot co m
edit: oh..this assuming you planned a parts kit as well. I thought you did but I may be mistaken:bigeyes:
Orignially posted by Russ White
I was thinking
Finally got a chance to look over the spec sheets, and it looks to me like the 620/9620/914's will substitute very nicely, especially that 914. They have my thumbs up!
Cheers, Terry
