The correct IR receiver was delivered today and was installed this evening - I now have functioning infra-red remote control.
Next weekend I will hopefully conenct up the Muses chip boards to the controller board and be able to get the volume control of my preamp workng.
Were you able to get it working?
I've had too much on to spend any time on this for a few weeks - I have been concentrating on getting things in place for the power amp that the pre-amp will drive - I have some time off work coming up so will hopefully complete the project soon.
Hi folks, trying to troubleshoot a V1 board. I am getting 0V on both outputs. Not shorted, both show ~470R to ground. All the +/-15V and +5V seem correct (using on board reg.). I've checked muses pins once for continuity/shorts and did not see any issues. I'll do that again with less tired eyes, but any troubleshooting tips or things to look for?
Dan
Dan
@Dan: is the controller ok? You can check the data lines to the muses or connect a display and check the remote learning procedure.
Hi - I hooked up the display and the display works. I will need to solder up the IR receiver as I've not done that yet. The encoder steps are odd as it skips around alot and will go down in numbers at times when turning to the right, especially if you turn it fast. Thanks - Dan
Hi 04dgmsilv
So far, so good… 👍🏼
I’m guessing you are using the original GB version of the board
Which display are you using?
and (from memory) some who implemented a display and remote had issues stemming from the power supply… are you using anything other than the on-the-board power supply?
So far, so good… 👍🏼
Thanks - Using meldano's V1 boards, adafruit display and a VRDN power supply for +/-15V and onboard reg for 5v. Will go over volume board again this weekend.
Success - Thanks for listening to my rambling, pin 17 on the muses chip was soldered poorly. Display is indeed super noisy connected directly, disconnected that and much cleaner. Connected up to a BA2018 Preamp build.
Hey everyone, just a couple basic questions for a beginner here:
1) is there a wiring diagram or any hi-res photos of muses volume integrated with the DCB1 Buffer?
2) Does the volume control require it's own power supply or can it share with the DCB1?
if you check this thread, you’ll find some users who build the Muses with DCB1.
If you use the Mainboard a own transformer or psu is necessary.
There are several ways for power supply.
Please let us know your existing psu specs.
Daniel
Daniel
Hi Daniel,
Do you have experience with the encoder em14 mentioned in another thread?
Can this replace the pec11l? Or do you also need an adapter for this?
Thanks,
Julian
Thanks,
Julian
Hi Julian,
wich other thread?
I have no experience with that type of encoder.
After a look to the datasheet: the encoder need a 5V DC supply. The Muses v2 supply is 3,3V. In case of using this encoder you have to check if the controller inputs are 5V tolerant!
Daniel
wich other thread?
Daniel
The thread is here: MUSES 72320 electronic volume
I think he used the 5v from the display.
Would this be possible?
Hi need help, finally finished the kit, connect it in a simple setup. It works after power on, get sound, however, as I turn the pot clockwise, the volume getting lower, until no sound at all. If I power off then on again, it repeats, get sound until turn the pot. Any step did I miss?
Is the rotary encoder correct connected?
Do you have the same behavior with the remote control?
Don't have remote control yet. Is the "rotary encoder" the chip came with the board?
Now after turned the pot many times, (both clock and anti-clock wise), it's not working, even power off and on again.
